2 Gen Coilovers-Which?Why?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by socal4x, Apr 8, 2011.
Coil Overs, Which, Why
Poll closed May 8, 2011.
  1. SAW 2.0
    0 vote(s)
    0.0%
  2. Fox Allpro 2.0
    2 vote(s)
    6.5%
  3. Icon 2.5
    29 vote(s)
    93.5%
  4. Radflo 2.0
    0 vote(s)
    0.0%
  1. Apr 8, 2011 at 6:17 PM
    socal4x
    socal4x [OP] Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    Made the decision to go with coilovers, I know I am probably beating a dead horse but figured I would provide an update thread for those that have been running coilovers for a while.
    For a mild <2" front lift, light off road:
    SAW 2.0s (had these on my 1 gen)
    Fox (allpro) 2.0s
    Icon 2.5 (no 2.0 I guess)
    Radflo 2.0s
    Which one and why? Do you have regrets one way or the other?
    Do these all need UCAs if only lifting 2"?
  2. Apr 8, 2011 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    @ 2" you shouldnt need UCA's to correct the alignment. Personally, I think the choice should include Kings, but, given what you list, Choose Fox if you like a progressive dampened suspension, or Icon if you prefer Digressive dampening.
  3. Apr 8, 2011 at 9:35 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    ^ this ang I have personal experience with the radflo's, they rode great at 2" and even 2.5" lift. but If you plan going any higher I would rec. a 1/4" top plate spacer.
    I switched to Icon ext. travel and they ride great! even at 3" lift. and they take bump and pot holes alot better.
  4. Apr 8, 2011 at 9:40 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Kings...but they are not on your list! So Icon then
  5. Apr 8, 2011 at 11:17 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Icon FTW, but Kings should be on the list they are also a great shock.
    I dont think you need the UCA's but if you cant get your alignment where you want it, then you will.
  6. Apr 9, 2011 at 9:40 AM
    socal4x
    CA
    Thanks! I didn't think to add the Kings, as I thought they may be too expensive...But worth the price it seems since it is mentioned by all.
    Radflo seems to be cheapest, but maybe a reason for that?
  7. Apr 9, 2011 at 9:48 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    I think Kings, Fox, and Icon are about the same price, i havent heard much about radflo's though.
  8. Apr 9, 2011 at 10:57 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Kings, Fox, Icon
    Which color do you like better?
  9. Apr 9, 2011 at 1:30 PM
    ETaco23
    Evan
    PNW
    Black and Blue FTW!! :)
  10. Apr 9, 2011 at 1:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not that easy. Fox & King are progressivce rate CO's, while the Icons are Digressive.
  11. Apr 9, 2011 at 4:25 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I used ToyTec ultimate coil-overs @ 2.5" and although not needed I replaced the UCA's with DSM's. Very happy with this setup
  12. Apr 9, 2011 at 9:30 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Chris, could you explain a bit what you mean by this? I am a bit confused.:confused:
    I am not at all familiar with the COs in question here, but when I hear "progressive rate" I think of a non-linear spring (no uniform spacing of coils) that gets progressively stiffer with deflection.
    As far as i know, "digressive" refers to the damping (shock), not the springs, and basically means the damping rate changes with speed or length of travel.
  13. Apr 9, 2011 at 10:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Progressive dampening progresively gets more firm as the shock shaft Velocity increases. Digressive shocks have more firm dampening at lower shaft velocity, and softer dampening at higher shaft speeds.
    More info:
    http://www.circletrack.com/techarticles/shock_absorber_shock_dyno/index.html
    http://autopitstop.net/car-improvements/progressive-dampers-vs-digressive-dampers/
  14. Apr 9, 2011 at 10:15 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    ^^^ So judging by those articles (all new to me) for everyday driving you want digressive dampening vs progressive?
  15. Apr 9, 2011 at 10:23 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    I thought it was the opposite.
  16. Apr 9, 2011 at 10:25 PM
    theduck911
    Max
    Locked and Geared!
    I really have no idea, it's all new to me
  17. Apr 9, 2011 at 10:39 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    It basically all depends on where you want the ride to be softer... high speeds or lower speeds.
    Say Icons with digressive are going to be more firm at lower speeds but will work better at higher speeds. Its the opposite for kings and fox with the progressive dampening
    Edit: someone correct me if im wrong, this is how i see it
  18. Apr 9, 2011 at 10:51 PM
    theduck911
    Max
    Locked and Geared!
    What's high speed though?! (like mph wise) or what is meant by high speed?
  19. Apr 10, 2011 at 6:32 AM
    qnyla
    NM
    I think it is the velocity of the shaft of the shock as the spring deflects. A fast displacement(like from hitting a bump at high mph) vs. a slower displacement (like from hitting the same bump at a lower mph).
  20. Apr 10, 2011 at 6:35 AM
    theduck911
    Max
    Locked and Geared!
    ^^^ oh okay, so typical drving is around 45-50mph (mine anyways) so like would that create a fast velocity or would it be considered slower?!
    ***Stupid Mobile should be able to quote things
