2 Gen OME Install Issues?
Discussion in 'Technical Chat' started by drab, Jun 29, 2013.
  1. Jun 29, 2013 at 11:09 AM
    drab
    drab [OP] New Member
    Portland, OR
    08 4Cyl SR5 4WD
    So I put my new OME suspension on the truck, along with 13mm spacers up front and Light Racing UCA's. Truck looks great, install was almost smooth.
    But, now my ABS light is on, I'm fairly sure that I just screwed up one of the sensor wires, although I don't know how to figure out which one without replacing them one at a time.
    The weirder one is my idle speed is now about 400 rpm, this one I really have no idea what I may have done.
    I did have the battery out of the truck for 2 days (long story), but still, I can't think of how any of this would effect idle speed.
    You guys got any ideas, I'm stumped.
  2. Jun 29, 2013 at 11:31 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    the bolded part is from the battery being out. go drive it around and it will settle back down. the reason its effects the idle speed is because u have reset the ECU of the truck.
    ur abs problem is probably a messed up wire. check out the cables going to the wheels and see if u find something obvious. if not, might have to take it to dealer and let them figure it out
  3. Jun 29, 2013 at 1:22 PM
    drab
    Portland, OR
    08 4Cyl SR5 4WD
    Well, computer finished thinking and idle speed back to normal.
    Had the folks at my alignment shop run an abs scan, looks like I let that left front drop with a little too much force. First wheel I did, kinda took me by surprise.
    Thanks for the help.
  4. Jun 29, 2013 at 1:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you have a multimeter you can rebuild that wire pretty easy.
  5. Jul 28, 2013 at 2:24 PM
    drab
    Portland, OR
    08 4Cyl SR5 4WD
    I figured I should update.
    All is well, I cut the plugs off the abs cable and used crimp splices on some home depot cable to put it all back together.
    The fix was about 6 bucks, the part from partsgeek is $144, code went away.
    I think I won.
