2 In Leveling Kit Installed now have slight rubbing (like) vibes
Discussion in 'Suspension' started by Shooter78, Feb 28, 2018.
  1. Mar 12, 2018 at 10:49 AM
    Pytoy
    Pytoy New Member
    Sharpish, can you tell me a little more about the needle bearings? Their location, is this expensive, where are they located, hard to install for a novice? Thank you for all your input. I was thinking about a front diff drop kit?? Would that help?
  2. Mar 12, 2018 at 11:01 AM
    TPC
    TPC Well-Known Member
    TIM
    DELAWARE
    2017 DCSB TRD SPORT
    Here is some reading. East Coast Gear Supply (ECGS) makes a bushing to replace the driver side needle bearing that typically has issues soon after a lift.
    https://www.tacomaworld.com/threads/front-diff-vibes-ecgs-bushing-fix.464941/
    This is the best install video I have seen:
    https://www.youtube.com/watch?v=m9W31KGy6k0
    I would gauge for yourself from the video how comfortable you would feel doing the work yourself.
  3. Mar 12, 2018 at 11:13 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The location is the front driver side cv axle where it meets the differential. There is a replacement bushing made by ecgs that solves the issue and seems relatively simple to install depending on your skill set.
    Honestly some google searches will fill you in on all the details vs me writing you an essay and missing things.
  4. Mar 12, 2018 at 11:17 AM
    Pytoy
    Pytoy New Member
    Boy you guys are fast on the responses!!! Thank you both very much!!
  5. Jan 29, 2019 at 3:47 PM
    saltybass
    saltybass Member
    Ovtune 1.04r, MBRB single exhaust, 2 inch level kit, 265/70/17 bgf KO2, 17x9 -12 wheels
    Reviving this thread...
    Current set up:
    2016 TRD Sport Manual (4x4)
    2-inch front strut spacer leveling kit (RC)
    17x9 Gear Alloy -12
    265/70/r17
    preface: tires and wheels installed a week before lift.... no problems pre-lift other than rubbing, which is totally expected from the setup.
    I had a 2 inch RC front level and have a strong rhythmic harmonic vibration too, HOWEVER, this is the front passenger side, not the driver side (which seems to be the needle bearing issue). RC customer support (which is was superb, even though it took a few phone calls) was stumped but after the 3rd call to them, they are sending me drop-down spacers to get better operational CV height. Does this sound accurate or like a good fix?
    The rhythmic vibration is every 1-2 seconds lasting for about a half second. Sounds rotational, vibration doesn't accelerate with speed, only more pronounced vibration. Seemed to be muted or gone in 4H.
  6. Jan 30, 2019 at 6:42 AM
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    Needle bearing. Get the eggs. I had the same issue.
