2 inch level kit on top of strut assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AvgJohn, Apr 18, 2022.
  1. Apr 18, 2022 at 8:29 AM
    AvgJohn
    AvgJohn [OP] Member
    I put the spacer on top of the strut assembly but when I put the strut back in the bracket that holds my brake line is not facing where it's supposed to it's almost 130° off. The instructions say to turn the hat, nothing to do with the spring just the hat of the strut assembly does anybody know how to do that safely?
    Thanks.
  2. Apr 18, 2022 at 8:31 AM
    guyfromky
    guyfromky Well-Known Member
    Why did you not put the strut assembly back in exactly the way it came out?
  3. Apr 18, 2022 at 12:49 PM
    AvgJohn
    AvgJohn [OP] Member
    As soon as you put the leveling disc on the bolt pattern changes in order to make it fit you have to turn the hat which was my question how to do that safely
  4. Apr 18, 2022 at 4:10 PM
    AvgJohn
    AvgJohn [OP] Member
    That is ingenious thank you!!!!
    did not think of that.
