2 inch leveling kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adelateur, Sep 15, 2016.
  1. Sep 15, 2016 at 10:35 PM
    adelateur
    adelateur [OP] Member
    2014 Green TRD
    hey everyone,
    I have had my 2014 taco TRD sport for a couple years now and have recently made a friend who sells tires. I've always wanted bigger tires for my truck but never really got around to it. Now I actually need new tires and have a hook up on cheap ones. So thinking about throwing in one of those 2 inch spacers on the front end to level it to fit 32's.
    Problem is I heard the spacers fuck up ride quality. .....and I've also heard that there is no difference and that they are the quick and easy fix I'm looking for.
    ....so which is it?
    ChadsPride likes this.
  2. Sep 18, 2016 at 5:47 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    i keep hearing both some say it rides good some say not. i think it depends on your preference and if you go off road or not. same as some say use differential drop and say not too. im beginning to think its trial and error for each of us lol
  3. Sep 18, 2016 at 6:19 AM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Go with Bilstein 5100's (middle setting). I've had Readylift level kit and it rode fine, then later upgraded to Bilsteins. Either way, you'll need an alignment. You might as well upgrade your stock suspension and do it right, IMO and experience.
    Coolerman, ChadsPride and Bray1197 like this.
  4. Sep 18, 2016 at 6:25 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    This is the logic I usually give someone that wants to buy a leveling or spacer lift kit..
    "Hm, $200 'lift kit' on a $32000 truck..makes sense"
    Do it one, do it right; buy once, cry one.
  5. Sep 18, 2016 at 6:33 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    My stock suspension is harsh as could be. I couldn't imagine what it would be like with a spacer kit.
  6. Sep 18, 2016 at 8:23 AM
    adelateur
    2014 Green TRD
    Geekhouse23 I get what you're sayin and have thought about that myself. Also this isn't the first time I've been told to upgrade to the bilstein 5100s so I think I'll find a solid lift kit that isn't a cheap piece of Chinese machined aluminum and while I've got everything apart in the garage, throw in the new shocks as well. Thank you all for your input.
  7. Sep 18, 2016 at 9:27 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    A top plate spacer kit will give you EXACTLY the same ride as you had BEFORE installing it. Same shock....Same coil....Same ride..... Where the problems can crop up is if/when you take the truck off road. Spacers push the suspension down, away from bump stops. If you compress the suspension far enough, the shock becomes the stop, rather than the bump stop itself. In a hard hit, this can bend/break the lower end of the shock. One remedy is to use a spacer equal to the thickness of the top plate spacer to move the bump stop down to where it makes contact before the shock bottoms. I wouldn't recommend using a spacer lift, but they aren't quite as evil as many portray them. If you ever plan on doing any real off roading, coils and shocks are the way to go.
    It is far BETTER to use longer coils/adjustable shocks. But, many many people have successfully used top plate spacers for a cheap alternative to full suspension lifts.
    Spring spacers...? Run away as fast as you can. They simply preload the coil which is always a sure bet to get a horrible ride.
  8. Sep 18, 2016 at 9:42 AM
    adelateur
    2014 Green TRD
    Thanks for the info, that's exactly what I needed to hear. No I don't do a ton of off-roading, mainly getting to the mountains for skiing and back but I do have to go off the beaten path for work a lot so all that info helps alot
  9. Sep 18, 2016 at 5:51 PM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    Suspension lift ... nuff said... if you can't afford it, pinch your pennies till you can. Don't cut corners... do it right once. You'll be glad you did.
  10. Sep 19, 2016 at 2:18 PM
    JStiner
    JStiner Well-Known Member
    11 MGM 4x4 4.0 double cab
    KO2s (32s) with 2inch level
    1. had a 2inch leveling puck with stock shocks and crap tires (33s). <- dont recommend this, its a bad ride, rubs all the time!
    2. replaced stock shocks with 5100s (still had 2 inch leveling puck and crap 33s) <- ride was better, but not good, still rubbed.
    3. replaced crap tires with KO2s (32s) <- much better ride, but not as good as it could be. no more rubbing
    4. she's going into the shop soon to have the puck removed and the 5100s used properly to level the truck on the KO2s (32s)
    learn from my stupid, do it right the first time instead of making adjustments the wrong/cheap way.
    my process ended up costing me more from not just going to a proper shop and having the 5100s put on correctly the first time.
    geekhouse23 likes this.
