2 inch Lift Kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dragon egg29, Apr 19, 2022.
  1. Apr 19, 2022 at 10:10 AM
    Dragon egg29
    Dragon egg29 [OP] Member
    2016 Toyota Tacoma
    Winch, Light bar and Pod lights
    Just wondering what all you need when lifting a 2016 DR5 Tacoma. I know that u-joint reinforcements but are there any other recommendations?
  2. Apr 19, 2022 at 10:13 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. Apr 19, 2022 at 10:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I did 1.5in with this and could have easily have gone higher with the same parts:
    -- Bilstein 5100 fronts
    -- Stock springs
    -- Bilstein 5125 extended travel rears
    -- Icon RXT packs on Option 1
    -- Front diff bushiing
    -- 1/4in or 3/8in carrier bearing shims
    Check with HotshotOffroad.com / @memario1214 for the parts.
    :cheers:
    memario1214 likes this.
  4. Apr 19, 2022 at 10:16 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    Good list. The only thing I would add is 2-3 degree axle shims might be needed. I did the carrier bearing drop and still had vibes so I added shims when I reinstalled the stock overload for a little extra height and they completely eliminated the vibes.
    If doing the lift install yourself you'll need:
    -Jack
    -Jackstands (6 ton are ideal for the height needed, plus the extra strength is worth it)
    -Wheels chocks
    -Sockets
    -Ratchet, breaker bar, torque wrench (impact will make life easier)
    -Spring compressor if not having your springs preassembled (can rent this from autozone/advance for free). You can also use the jack to compress the spring as you mount it, there's a few videos showing how but it might be a bit sketchy
    Assorted wrenches
    -A friend makes the rear end much easier
    509 buckeye and tonered[QUOTED] like this.
  5. Apr 19, 2022 at 10:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
    Good point!
    :cheers:
    I had slight vibes taking off in 1st gear that the carrier bearing shims solved for me.
  6. Apr 19, 2022 at 11:21 AM
    coma toy
    coma toy Off Road Taco
    2/1" Bilstein 5100 is the best bang for the buck. Bilstein even recommends you keep the stock coils up front.
    u-joint reinforcements??????
    VaToy likes this.
