2" leveling kit
Discussion in 'Suspension' started by pse1cam, Sep 11, 2010.
  1. Sep 11, 2010 at 10:25 AM
    pse1cam
    pse1cam [OP] Member
    pse1cam
    idaho
    2010 tacoma SR5 trd
    procomp 6" stage 1
    i put a 2" leveling kit on my 07 tacoma last year. now when i take it off roading, i am having trouble with my rear shocks bottoming out. can some one help me out with this. do i just need new shocks, an add a leaf, or both.
    thanks in advance.
  2. Sep 11, 2010 at 2:55 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Need a litte more info. Did the leveling kit come with an add a leaf, a block, or was it just a front leveling kit?
    Do you have the rear spring TSB performed? How many leafs total do you have in the back?
    when you say the shocks are bottoming out, is that during droop, or are the leafs hitting the bump stops?
  3. Sep 11, 2010 at 6:53 PM
    pse1cam
    pse1cam [OP] Member
    pse1cam
    idaho
    2010 tacoma SR5 trd
    procomp 6" stage 1
    thank you kpt for responding. the leveling kit is only a 2" front leveling kit. nothing has been done to rear of the truck. i only have the 3 stock leafs on the the back. yes, it is the leafs hitting the bump stops. but it seems to happen a lot. also bow hunting season did just start here so i am spending a lot more time in the hills.
    1 more thing i only have 25000 miles on my truck. so don't think it would be shock failure already, but i do drive it pretty hard.
  4. Sep 11, 2010 at 7:34 PM
    TexasTacoma37
    First thing I would try is an add a leaf. That will stiffen up the rear. You can get one for under $100 from wheelers offroad or fat bob's garage.
  5. Sep 11, 2010 at 7:36 PM
    pse1cam
    pse1cam [OP] Member
    pse1cam
    idaho
    2010 tacoma SR5 trd
    procomp 6" stage 1
    thanks, will give it a try.
  6. Sep 12, 2010 at 12:51 PM
    lynyrd3
    Bill
    East Central Upstate NY
    You should have the suspension TSB done if possible .
  7. Sep 12, 2010 at 1:18 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    On my 07 I had aal's installed with the lift right after I bought the truck and have never experienced a bottoming out issue or axle wrap. The tsb that installs the aal's for free will do the same thing if you can still get it done under warrenty.
  8. Sep 12, 2010 at 1:34 PM
    pse1cam
    pse1cam [OP] Member
    pse1cam
    idaho
    2010 tacoma SR5 trd
    procomp 6" stage 1
    sweet i will call my dealer tomorrow. my truck is still under warranty. thanks alot.
