2" Lift Blocks
Discussion in 'Texas' started by OkieDan, Jan 9, 2024.
  1. Jan 9, 2024 at 2:14 PM
    OkieDan
    OkieDan [OP] New Member
    Dan
    Edmond, OK
    2019 Tacoma SR5
    If I install 2" lift blocks on my 2019 Tacoma, will I need to replace my rear shocks?
  2. Jan 9, 2024 at 2:18 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It depends. Where are the blocks being added (F or R)? What is the trucks current stance? Regardless. The rear shocks do not control height. The rear leaf springs adjust the height.
  3. Jan 9, 2024 at 2:24 PM
    OkieDan
    Dan
    Edmond, OK
    2019 Tacoma SR5
    I installed a 2" leveling kit on the front and now it sets higher than the rear. I was thinking about using 2" lift blocks in the rear to level it out. Before I install them I was wondering if my stock shocks would work.
  4. Jan 10, 2024 at 11:26 AM
    pivey14
    pivey14 Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    I am running 2" rear blocks on stock shocks. While I like retaining rake, the ride could be better, but it's not terrible for daily driving. Doing AAL and Coilovers in the near future.
  5. Jan 10, 2024 at 12:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    2" up front and 2" in back won't be level. It will have the same rake as you started with.
    Maybe your ok with that. But you did refer to it as a leveling kit, so thinking that was your goal?
    gotoman1969 likes this.
  6. Jan 10, 2024 at 7:38 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Put a 1” block in the rear. As @Clearwater Bill said if you do a 2” you’ll be right back where you started just 2” higher.
  7. Jan 10, 2024 at 7:42 PM
    Bishop84
    Bishop84 Well-Known Member
    You can run stock but no down travel, it will ride awful on a rough road.
    I'm voting for 1" block lift, or proper longer shocks.
