2" lift in front do I need to lift back to level (no tsb aal)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachMX, Feb 12, 2013.
  1. Feb 12, 2013 at 12:37 PM
    ZachMX
    ZachMX [OP] Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Doing a 2" spacer lift (so 1" spacer) for the front to level the truck. I have a 4wd Sr5 without the TSB (standard leaf pack). Was wondering if I will need to aal or a 1'' block in the back, what do you guys think? if its only a smudge high in the front I wont be to upset. Just no "bro lean". Tried to search for this and only found people doing 1.75'' on the billies to level with no tsb. Thanks in advance.
  2. Feb 12, 2013 at 12:38 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Should sit pretty level like that.
  3. Feb 12, 2013 at 12:39 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Billies don't add lift to the rear. You need an AAL or the 3 leaf add on. You can also get a 2" lift with some IronMan leaf springs.
  4. Feb 12, 2013 at 12:39 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    It will probably will be a little high in the front, but only barley. If you do blocks or an AAL you will get some of your rake restored and it wont be really nose up when you have a load in the bed.
  5. Feb 12, 2013 at 12:52 PM
    ZachMX
    I never said they did, people add billies in front, adjust to 1.75 and thats it to level their trucks. I'm doing a 1'' spacer (2'' of lift) in front to level my truck. Was just concerned with the rear and not wanting to have any lean since I only have the standard 3 leaf pack.
  6. Feb 12, 2013 at 12:53 PM
    ZachMX
    thanks!
  7. Feb 12, 2013 at 12:53 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    With 5100's at 1.75 and TSB (4 leaf pack), truck should be about level. If you are setting the front to 2" it may be a little higher up front
    Seem like you don't have TSB leafs, so with a 3 leaf pack you will be definitelly nose high.
    You need an aal or get TSB leafs if you are eligible, or a new leaf pack etc.
  8. Feb 12, 2013 at 12:59 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    If you are adding a spacer, you may as well get the billies. Only reason I say that is it is the same procedure to add a spacer as it is billies.
    If you want to level out the back, go with wheelers aal or something similar. You can also order the dakars and remove the overload leaf. I know people do that for less of a lift.
  9. Feb 12, 2013 at 1:09 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    ^X2 and a 1.5" aal or progressive pack for the rear. I would go with the 5100's for the front set at 1.75. You will get a much better ride and bang for your buck.
  10. Feb 12, 2013 at 3:27 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Just to give you an idea. I also have an access cab with billies set at 2.5" in front with 1.5" AAL in rear and that pretty much leveled me out. So I guess that would mean if I had the front set at 1.75" with no rear AAL that would be about .75" higher in the front.
