2" lift kit for '99
Discussion in '1st Gen. Tacomas (1995-2004)' started by VBdiver58, Aug 12, 2023.
  1. Aug 12, 2023 at 9:26 PM
    VBdiver58
    VBdiver58 [OP] Well-Known Member
    Virginia
    1999 Tacoma xtra cab 4x4 2.7L
    16" Toyota rims
    I got an estimate at local 4x4 custom shop for my '99 Taco . Quote was for a 2" lift on front Billstein shocks and reuse my coils and Billstein shocks on rear with a 1" lift to rear that I am told will level out the vehicle . It is 1" lower in front measured at top of wheel well.
    $1400 for parts , labor & including alignment .
    Does that sound like a fair price ?
    Anything I should enquire about or caution moving forward ?
  2. Aug 12, 2023 at 10:09 PM
    02hilux
    Planet: EARTH
    DIY? Check your regional location for MOD DAY
    VBdiver58[OP] likes this.
  3. Aug 12, 2023 at 10:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As @02hilux mentioned it's a super simple DIY
    With the exception of the coil on shock assembly; I'd just buy a Bilstein coilover (with OME coils) so you can swap them out.
    Save a ton of money on labor and just get an alignment once you're done.
  4. Aug 12, 2023 at 10:32 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would at minimum ask for an itemized quote. A break down on what exactly they would be installing, prices for each part, price of labor and what level of alignment. Make sure they would be setting caster, camber and toe and guarantee the parts and their work. It could be done a lot cheaper if you or a qualified buddy could do the work then just have a qualified alignment tech do the alignment.
    VBdiver58[QUOTED][OP] likes this.
