2" lift rubbing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coronerrpm, Dec 23, 2019.
  1. Dec 23, 2019 at 7:52 PM
    Coronerrpm
    Coronerrpm [OP] Well-Known Member
    Bob
    2017 Tacoma sport
    Before I get my ass handed to me for this post. YES I searched 100+ posts but can’t find an answer to this. (Might have missed it. ( If so my bad) if I go with a bistsein 5100 2”lift and and AAL on the rear (I only want 2”total lift) and I have 265/70-17 duratracs (love them) tires on a 2017 sport with factory rims can I run 1.25” wheel spacers? I removed mud flaps as well as the crappy air dam in the front with out rubbing?
    And again I went threw tons of posts and can’t find a straight answer.
    thanks again and please keep the research crap down. As I said I searched but maybe did not word it correctly. Anyway any info would help.
    cheers
    Junkhead likes this.
  2. Dec 23, 2019 at 8:03 PM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    I have a 2017 Sport, stock wheels, 265/70/17 Falken Wildpeaks, 1.25 Spidertrax spacers with no lift. I had a slight rub on hard corners but it was easily remedied with a heat gun. No more rub. You will be fine.
  3. Dec 23, 2019 at 8:07 PM
    Bishop84
    Bishop84 Well-Known Member
    It's the rims, the TRD sport rims have poor backspacing, the offroad has +25 and the sport has +30 makes a world of difference.
    Try marking where the rubbing is, cut or gently melt with a heat gun.
  4. Dec 23, 2019 at 8:30 PM
    Coronerrpm
    Bob
    2017 Tacoma sport
    Thanks for reply's what I was asking with the lift kit mentioned will I rub with spacers. 1.25”? No mud flaps, no air dam in front
    Looking for a good stance
  5. Dec 23, 2019 at 11:12 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
  6. Dec 23, 2019 at 11:17 PM
    CaptainBart45
    Bart
    Work in progress...
    Run around your house with a 10 pound weight and tell me if it is easier to carry close to your body or a little farther out from your body.
    edgarcg2 likes this.
  7. Dec 24, 2019 at 8:50 AM
    KrzyJZB
    KrzyJZB New Member
    2020 Cement Gray Tacoma TRD Sport
    3” Billsteins 285/70/17 on stock sport rims
    My truck went straight from dealer to shop to get lifted. Really wanted that aggressive look but want to keep the sport rims. Put on 285’s and I was rubbing the UCA at full turn. 1/4” inch spacer and I’m good to go!
  8. Dec 25, 2019 at 4:31 AM
    Da Boogie Man
    Seymour
    The rubbing happens at the bottom of the wheel wells. If you lift it, the bottom of the wells will be above the point where the tire can rub them.
  9. Dec 25, 2019 at 4:36 AM
    Coronerrpm
    Bob
    2017 Tacoma sport
    Thank you
  10. Dec 25, 2019 at 4:49 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The reason you couldn’t find a straight answer, is there isn’t one. There’s way too many variables at play for someone to definitively tell you if you rub or not.
    that said, you’ll likely be fine. At most have to trim some plastic with a razor blade
  11. Dec 25, 2019 at 7:33 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    :eek::eek:
    :facepalm:
