2 lifts in 1 truck
Discussion in 'Suspension' started by zcolson, Nov 22, 2008.
  1. Nov 22, 2008 at 7:41 AM
    zcolson
    zcolson [OP] Member
    Northville New York
    02 tacoma singlecab
    3" toytec lift 3" tires
    Does any one know if I could put a 3" spacer with an AAL lift in my tacoma and then put 3" bigger coils with 3" shackles without putting a drop bracket in for the front pumpkin? I am also wondering about the A arms and if they would have to be extended?
  2. Nov 22, 2008 at 3:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    3" spacer with 3" coils would ride slightly worse than if you were to weld you front suspension soild. You would destroy your ball joints, and Cv's. If your looking for a 6" lift, than go with a dedicated drop bracket 6" lift. "Stacking" lifts is a horrible idea. For the rear, you CAN add 3" shackels, but keep in mind, they are 6" long. Better off getting a new leaf pack.
  3. Nov 22, 2008 at 6:46 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    if u want 6" u need a 6" lift not 2 x 3" lifts. u cant do it.
  4. Nov 23, 2008 at 8:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    With 3" coils & 3" spacer (assuming it's mounted inside the coil assembly) will never work. The mounting location on the strut tube will break. They're not built to handle that much pressure. I've seen it happen with only 2.5" coils and a 1" spacer.
    If you want 6" lift - buy a 6" lift kit.
