2 Lo mod ideas? (MT if that makes a difference)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by duckytw, Mar 25, 2017.
  1. Mar 25, 2017 at 8:49 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    They're in the OP.
    Post #6, I explain what I noticed was different.
    iPaint[QUOTED] likes this.
  2. Mar 25, 2017 at 9:18 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Clutch is disposable, remember that.
  3. Mar 25, 2017 at 9:30 PM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    Disagree. The clutch is in not disposable. I could not live without my clutch. It is however a consumable. But, that does not mean that we should not look for ways for it to be consumed at a lower rate.
  4. Mar 25, 2017 at 9:30 PM
    iPaint
    iPaint Well-Known Member
    Nebraska
    2017 TRD OR DC 4x4 AT
    I know the clutch is a consumable item but I'm not ready to give up on this either. If the computer is so advanced compared to a 2nd gen, I wonder if something could be changed with a tuner (when one becomes available) where something could be deactivated with a switch and whatever would have pissed the computer off could then be ignored. Uncharted territory deep within uncharted territory at this point I guess.
  5. Mar 25, 2017 at 9:37 PM
    specter208
    California
    Install a front bumper mounted tow hitch and push that sum' bitch up your driveway! Yeehaw!!
    :burnrubber:
    Av8rJake likes this.
  6. Mar 25, 2017 at 9:39 PM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    I'm hoping that someone figure this out because I plan on pulling a TT of some sort and I hate the smell of burning clutch.
  7. Mar 25, 2017 at 9:41 PM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    Certainly an option...but not a particularly convenient one.
  8. Mar 25, 2017 at 9:54 PM
    duckytw
    duckytw [OP] Well-Known Member
    Good call... Id probably have to download the 2nd gen wiring diagram to confirm that they dont have the skid control, but even following that lead on the 3rd gen, I dont see anything on there that would directly control the diff lock on the 4wd computer (could be wrong though because it does have BE, GR, and W wires feeding back to it from the skid ecu).
  9. Mar 26, 2017 at 8:58 PM
    iPaint
    Nebraska
    Orangevirus responded about my tune inquiry for the 3rd gen. I responded with the question about the 4wd system operation within the computer and if there was anything that would help with a 2wd Lo mod.
    "Hello yes we are! thank you for your inquiry.
    We plan our initial, limited release on our reflash tuning early summer / late spring for the 2GR KFS 3.5L Tacoma Engine
    Mathew Wilson
    OrangeVirus Tuning Ltd.
    And in regards to the 4wd system and the computer when trying to achieve a 2wd Lo range function:
    "We can't give out too many details yet, but once we are ready we will release details about what is possible, what we change, etc."
  10. Mar 26, 2017 at 9:51 PM
    duckytw
    Now that's exciting news and could be a seriously clean solution.
  11. Dec 20, 2017 at 9:20 AM
    duckytw
    Curious if anyone has made some headway into this project yet? Got some non-snow hill driving coming up, with loaded truck and/or trailer, and probably reversing will be required! I might have to see this one through myself, but as Im no electronics expert, I doubt Ill make any dent in it for a while. In the meantime, I saw the 2nd gen stuff-- super nice! https://www.tacomaworld.com/threads/mod-for-2-lo-on-late-model-2nd-gen.464971/page-2
    https://www.tacomaworld.com/threads...thread-pic-heavy.377840/page-74#post-15172289
  12. Dec 20, 2017 at 1:26 PM
    thdrduck
    thdrduck Well-Known Member
    I would also like to know. This could be the most useful mod for a mt tacoma.
    specter208 and jtmiller2011 like this.
  13. Dec 20, 2017 at 5:54 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I would expect the modification to the wiring that was done to the older models to work fine on the newer ones as well. The front ADD operates exactly the same on the 2016+. This is just not allowing the front diff to engage and telling the ECU that it is in fact engaged.
    The wiring is different, so you'll want to make sure it is done correctly, but once done properly, it will work the same as it did on the older models. The ADD wire that splits off to the skid control computer that was mentioned shouldn't cause any issues I don't think, but if it did, you can just change where you intercept that wire (between the ECU and the junction will prevent the skid control from thinking the truck is in 4WD, which is ideal, however if this is an issue, it can be intercepted between the junction and the differential actuator instead to maintain continuity to the skid control computer).
    Jeff
  14. Dec 20, 2017 at 6:11 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Manual hub conversion
    Jeff Lange likes this.
  15. Dec 20, 2017 at 10:50 PM
    #35
    duckytw
    I think youre onto something. I downloaded both a 2013 wiring diagram and the 3rd gen and they appear to be wired up exactly the same with the 1 exception that the 3rd gen sends a signal to the skid control ECU. 2nd gens also have the skid control ECU, but they dont appear to have any additional signals when switching to 4wd. But as far as I can see, the other wires look to be 100% same function with the 2nd gen 2lo mod. So the only question is: how picky/integrated is the skid control computer...
  16. Dec 22, 2017 at 5:34 AM
    #36
    thdrduck
    Not to sound like an idiot... what is a skid control computer and do all models of 3rd gen have them? Function?
  17. Dec 22, 2017 at 7:20 AM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The hubs is not where the front shafts engage. It's in the diff.
    In a perfect world, I'd wish for twin sticks and manual hubs myself.
  18. Dec 22, 2017 at 8:40 AM
    #38
    jmaack
    Justin
    Helena Alabama
    yeah but if you didnt lock your hubs in and put in 4wd would the truck know that? This what i am ho[ping for anyways when i finally buy kit early in coming year.
  19. Dec 22, 2017 at 9:07 AM
    #39
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    @ducktw you have options OP.
    1) Learn to get the truck in reverse and back it up in gear rather than slip the clutch the whole way, trust me it works I backed a boat uphill into my buddies driveway still using that technique and going real slow. You can brake in reverse to avoid flying back.
    2) do manual hub conversion as @jmaack and others have stated
    3) take your front driveshaft out and engage 4lo as normal. It won't do anything bad to run it that way, you'll just be stuck with 2wd until you put the shaft back in. There are 4 bolts on each end of the shaft and then you should be able to fenagle it out
    May have to remove skid plates or other bs depending on your setup
    specter208 likes this.
  20. Dec 23, 2017 at 2:27 PM
    #40
    specter208
    California
    Probably would temporarly remove front drive shaft.
