2 LO MOD
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotadan98, Nov 11, 2012.
  1. Dec 19, 2012 at 10:03 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Isn't it called the Blue Wire Mod?
  2. Mar 5, 2014 at 8:14 AM
    ELMO67
    ELMO67 Well-Known Member
    Ct.
    04 Tacoma 4wd reg. cab
    Ok, bringing this one back for the dummies(me). I have the manual shifter, no switch, on my '04 Tacoma 2.7 5spd. What exactly do I need to do to have 2wd low? I have read a few threads, but they are a little vague- to me.
  3. Mar 5, 2014 at 8:53 AM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Unfortunately if you have the manual J shifter for 4wd then you can't do this mod.
  4. Mar 5, 2014 at 8:57 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
  5. Mar 5, 2014 at 9:02 AM
    Enigmaaron
    PA
    1st gen superiority
  6. Mar 5, 2014 at 9:03 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Ahhh, well then yes you are correct
  7. Mar 5, 2014 at 12:53 PM
    ELMO67
    Ct.
    That's it! Thank-you!
  8. Mar 5, 2014 at 6:12 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    I did the two low mod on my 02 taco yes unplug the blue plug as described, although when you want four low you have to move shifter to low range then push the button on the shifter. It takes all of one minute to crawl under your truck and unplug the wiring. After it's unplugged shrink tube the connections to keep water out. The two lo mod is great for backing a trailer into a tight spot saves on your clutch and your truck isn't binding up if your turning tight.
  9. Mar 5, 2014 at 6:16 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    This doesn't work for the J-Shift transfer case. Those of us with the J-shift case have a little more involved process.
  10. Mar 5, 2014 at 6:19 PM
    Pakrat
    Brian
    There is a mod for the two lo mod for the j-shift but you have to wire in a switch to the four wheel drive control box on the passenger side kick panel just a FYI!!,
  11. Mar 5, 2014 at 10:51 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Don't forget that if you have the j-shift and manual hubs 2WD LO is very easy, just don't lock the front hubs.
