2 Low or 4 low
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000GTacoma, Sep 15, 2011.
  1. Sep 15, 2011 at 7:48 PM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    My dad has an old toyota with manual hubs. He can pu the tcase in 4low without locking hubs and get 2low. Is there a way to do this on the ADD with a switch? Flip a switch and it is 2low flip the over way and have 4 low
    2000 tacoma 3.4l manual 5 speed
  2. Sep 15, 2011 at 7:49 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Why doesn't your father just twin stick it and pull the interlock pin out of it.
    Then he can get a REAL 2Lo..
    and no unless you use a driveshaft disconnect.
  3. Sep 15, 2011 at 7:51 PM
    2000GTacoma
    Snow Hill NC
    he isnt into crawling or anything like that its an 88 with the 22re in it. tough little truck
  4. Sep 15, 2011 at 7:52 PM
    2000GTacoma
    Snow Hill NC
    i thought i had heard of it before. Basically you either allow the trigger wire to engage the ADD or not with a switch i think. I tried doing a search with little help. Maybe I overlooked. and I will look over a ttora
  5. Sep 15, 2011 at 7:54 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    it wouldnt be a good idea since the add only disconnects the right side. it would unnecessarily work on the diff
    if the truck you are talking about is the 2000 you could get manual hubs for it off of a older first gen
  6. Sep 15, 2011 at 7:55 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    If he isn't into crawling then no need for 2 lo?
    If you just play around offroad...2Hi and 4lo is all you'll need.
    2Hi for driving, 4lo for getting stuck and getting out.
    Duh.
    lol.
    My buddy's 83 is twin sticked, but he has a 4:7 rear case and crawl box in it also..super fun 2Lo with crawl box engaged :cool:
  7. Sep 15, 2011 at 7:57 PM
    Yoytoda
    Roland
    completely stock
    why would you crawl in 2lo
    2lo is good for traffic, hill descending
  8. Sep 15, 2011 at 7:57 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
  9. Sep 15, 2011 at 7:57 PM
    2000GTacoma
    Snow Hill NC
    ahh i did not know it only disconnects one side. Thanks and I don't need 2low that bad to change to manual hubs. I like driving in the snow and engage 4WD without getting out. I rarely even use 4WD. I use it just enough to keep things working and even then i can tell i dont use it enough
  10. Sep 15, 2011 at 7:58 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Challenging.
    We don't do rock gardens or anything of that like, 4 wheel engaged is not needed. What we mess around on isn't like Fordcye or Rubicon status.
    We do alot of descents, small drop offs, small pop ups, and tree/brush climbing.
    It's like a rollercoaster.
  11. Sep 15, 2011 at 7:59 PM
    2000GTacoma
    Snow Hill NC
    he just does it moving around heavy trailers especially where we hunt to move tractors and in without riding the clutch too much
  12. Sep 15, 2011 at 8:00 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    So instead of just rushing up it..2LO will crawl up it
    Know what I mean?
  13. Sep 15, 2011 at 8:00 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Ah that makes perfect sense :D
    I'd use it to move heavy trailers too lol
  14. Sep 15, 2011 at 8:03 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Tacoma cases are chain driven..you can't even twinstick it can you?
    The stock case at least.
    Are they topshift or side?
  15. Sep 15, 2011 at 8:03 PM
    Yoytoda
    Roland
    completely stock
    yea kinda... it would be nice to use 4lo when you dont need the traction of 4lo but need the gearing...
  16. Sep 15, 2011 at 8:04 PM
    2000GTacoma
    Snow Hill NC
    exactly
  17. Sep 15, 2011 at 8:05 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Spot on..
  18. Sep 15, 2011 at 8:05 PM
    Yoytoda
    Roland
    completely stock
    you can twin stick the fj case which is the same chain driven case but since its already lever actuated its easier. i dont know exactly how though...
  19. Sep 15, 2011 at 8:07 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Interesting!
    Love my 89 :D
    Just got this one..gonna start building it sooon.
    Probably lock the rear first, then twin stick it.
    Then armor.
    Don't plan on locking front, as truck is gonna get sas'ed eventually.
    Edit: to op..goodluck and i'll do research for you on Marlin Crawler.
  20. Sep 15, 2011 at 8:11 PM
    2000GTacoma
    Snow Hill NC
    i dont want to crawl i dont even offroad but from time to time backing a heavy trailer it would be nice to have 2 LO for gearing and without using 4 low where it cant slip
