2" Motofab leveling kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by DanK83, Nov 22, 2019.
  1. Nov 22, 2019 at 6:03 PM
    DanK83
    DanK83 [OP] Well-Known Member
    Dan
    Maine
    2003 Tacoma SR5 V6 4X4
    I'm thinking of installing a 2" leveling kit on my '03 Tacoma. Will I need new struts that are longer? I've read both yes and no. Any help is appreciated
  2. Nov 22, 2019 at 7:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There is no such thing as a "leveling" kit for our trucks, and our trucks use shocks not struts. Don't take this the wrong way, just educating you.
    Especially when you attach a unit of measurement next to it, that means you're looking at a lift kit.
    With that being said, there are different types of kits - the spacer/block kit which we all advise against, and suspension lift.
    I looked up "Motofab" and see that they sell a spacer kit, which again, we advise against but if you did go that route, you don't need to change out your shocks.
    Simply stepping up your budget a little more can net you Bilstein 5100's or the OME kit which both provide better ride quality, especially off road, and get you a real suspension lift.
  3. Nov 22, 2019 at 7:36 PM
    DanK83
    Dan
    Maine
    Right. I kniw they're shocks but read that the coil over, and the shock 'hiusibg' makes the shock is considered a strut. I've always calledthem shocks in the past. Anyway, I thought of just buying the 2" spacers that bolt to the top of shock mount. I got slightlybigger tires and bough 1.25" spidertrax wheel spacers as well
  4. Nov 22, 2019 at 7:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Correct; it is a coil over. But if you bought them as individual parts, it consists of a shock and coil spring and together they become a coil over.
    Anyway with that being said, a 2" spacer on top of your shock is just overkill for a spacer lift.
    Don't do it.
    I'll let others chime in, I'm out.
  5. Nov 22, 2019 at 7:48 PM
    DanK83
    Dan
    Maine
    Okay, thanks for your help
