2 New alternators still not charging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ben95, Mar 16, 2025.
  1. Mar 16, 2025 at 11:13 AM
    Ben95
    Ben95 [OP] Well-Known Member
    Ben
    North GA
    2012 TRD OR Grey
    I have replaced my alternator twice and still no luck. I've put a multimeter directly on the alternator while the truck is running and only getting battery voltage. I held the positive on the 10mm strap and the negative on the alternator case. What am I missing? Truck shuts off if I disconnect the battery while running.
  2. Mar 16, 2025 at 11:16 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Does the 2nd gen have an exciter wire to the alternator? That should be a single wire ignition switched 12v source that is used to generate the initial magnetic field the alternator requires to generate electricity. If it isn’t attached or wired properly the alternator will never work.
    Ben95[OP] likes this.
  3. Mar 16, 2025 at 11:18 AM
    Ben95
    Ben
    North GA
    2012 TRD OR Grey
    I'm not sure. I'm trying to find that out. I'm trying to decode the wiring diagram for the plug that goes to the fuse box.
  4. Mar 16, 2025 at 11:20 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
  5. Mar 16, 2025 at 11:21 AM
    Ben95
    Ben
    North GA
    2012 TRD OR Grey
    DavesSR5[QUOTED] likes this.
  6. Mar 16, 2025 at 11:39 AM
    Ben95
    Ben
    North GA
    2012 TRD OR Grey
    It looks like the 10A ign no2 fuse might be the exciter. Mine was blown. replaced it and it immediately blew again.
    UPDATE, I had some kind of short in a fuse tap I had on that fuse. Took out the fuse tap and it's fine now. Check that fuse before you replace your alternator! Hope this saves someone money someday.
    DavesSR5 likes this.
  7. Mar 16, 2025 at 12:04 PM
    Ben95
    Ben
    North GA
    2012 TRD OR Grey
    This put me on the right track while looking through this thread. https://www.tacomaworld.com/threads/need-help-wiring-alternator-plug-broken.705909/
    So thanks!
    DavesSR5 and crazysccrmd[QUOTED] like this.
