2 ohms speakers
Discussion in 'Audio & Video' started by machman, Sep 3, 2009.
  1. Jan 25, 2021 at 10:09 PM
    #41
    Yodastacotruck
    Yodastacotruck Well-Known Member
    2021 MGM 4x4 trd off road
    Stock
    Are the stock front door speakers wired in parallel with the dash tweeters? Anyone know the ohms?
  2. Jan 26, 2021 at 3:58 AM
    #42
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Mine came out to 4.3 Ohms when I metered them the other day. Yes they are wired in parallel.
  3. Jan 26, 2021 at 10:53 AM
    #43
    Yodastacotruck
    Stock
    i swapped them out for the Subaru kicker tweeters and kicker cs speakers I know the kicker cs is 4ohm I wonder if it would be the same ohms now that those 2 are wired together, I am also going to add an amp I don’t believe those tweeters Will handle that many rms if I send like 50 watts to the door speakers since there wired together? Wonder if there is a crossover somewhere?
  4. Jan 26, 2021 at 11:56 AM
    #44
    dolbytone
    South Carolina
    09 TRD Off Road
    The factory system was wired to 2 Ohms nominal since its all wired parallel. It’s part of the reason the factory system sucks IMO.
    It’s typical that tweeters don’t handle the kind of power woofers do, but they don’t need to since high frequencies require much less energy to reproduce.
    There is a no crossover but a filter capacitor wired to the tweeter. That’s true for the OEM speaker, and most probably likely for sure-ish on the Subaru tweeters.
  5. Jan 26, 2021 at 1:21 PM
    #45
    Yodastacotruck
    Stock
    Yeah on the Subaru tweeter there a little black box molded to the back must be the capacitor, so because the tweeters are wired in parallel with the door speakers it’s giving a two ohm load is that correct? And the factory 15 watts to the front channel sharing the load with the tweeter at 2ohm and if I send say 45watts rms to the front speakers 45 watts rms will also go to the tweeter with the only thing protecting it is the little capacitor which I’m not sure how many watts it’s rated at rms as the box had no info
  6. Jan 26, 2021 at 2:23 PM
    #46
    dolbytone
    South Carolina
    09 TRD Off Road
    If your tweeter and woofer were getting equal power, the tweeter would be eating your face off. When it sounds balanced the power distribution is disproportionate.
    Whatever you send to the front speakers, unless it sounds like it has way too much High, the HF speaker is maybe getting 1/3 of that. It depends on where the crossover point is.
  7. Jan 26, 2021 at 3:16 PM
    #47
    Yodastacotruck
    Stock
    I think
    It would be better to bypass the factory tweeters and run a set of components direct to the amp and bypass the factory harness
  8. Jan 26, 2021 at 8:27 PM
    #48
    dolbytone
    South Carolina
    09 TRD Off Road
    Your call but unless you plan to bi-amp or run a lot of power, or you have components with a two way crossover, it’s not necessary and there isn’t any benefit.
  9. Jan 26, 2021 at 10:47 PM
    #49
    Yodastacotruck
    Stock
    yeah your probably right, I don’t want nothing crazy only want to run like 50 watts to each speaker, I’ve learned anything more than that it’s a never ending rabbit hole
