2 or 1 Wheel Drive??
Discussion in '1st Gen. Tacomas (1995-2004)' started by archerytarget, Dec 18, 2008.
  1. Dec 18, 2008 at 8:45 PM
    archerytarget
    archerytarget [OP] BTHOB
    College Station, TX
    01 PreRunner SR5
    Brush guard, KC HiLites SlimLites, Chrome tube side steps, Deck plate mod, Cobra 19 Ultra III, 2' cb antenna, Painted black stock wheels, TSC toolbox, Sprayed-on bedliner, Trailer hitch, Homemade headache rack with rear lights, spidertrax spacers, 3" OME coilover lift
    are 2 wheel drive 1st gen. tacoma's really two wheel drive or just one wheel? i'm curious because on and off ive noticed that when i slip on slick streets the noise from the spinning tire is coming from the right rear tire. and ive gotten stuck sometimes off-road, but ive noticed that if i hit a mud hole with just my left side, i make it through just fine. im thinking its because the right rear is the one with the power. i dont know a whole bunch about rear diff locking and im pretty sure my truck doesnt have traction control :confused:...ive always wondered about this, can anyone explain/help?
  2. Dec 18, 2008 at 8:56 PM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    Well it's fairly simple. Power is being sent to the rear axle, which powers both rear wheels. The thing about power though, is that it has a habit of following the path of least resistance. Apparently your right tire is that path. The role of a differential lock is to force both sides of the axle to spin at the same speed, therefore equally distributing the power.
  3. Dec 18, 2008 at 9:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  4. Dec 18, 2008 at 9:06 PM
    archerytarget
    College Station, TX
    01 PreRunner SR5
    so there is power going to the left rear right?
  5. Dec 18, 2008 at 9:14 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I've noticed something similar as well! Thanks for the link Chris!
  6. Dec 18, 2008 at 9:39 PM
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    And your front left will get the power up front...
    So why, other than least resistance, is this always the case?
    And how exactly does the locker work?
  7. Dec 19, 2008 at 6:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Dec 19, 2008 at 7:04 AM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
  9. Dec 19, 2008 at 7:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What? Link no good?
  10. Dec 19, 2008 at 11:13 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    The link is good.
    Most cars have a lighter side left to right and front to back.
    So the tire that is on the lightess side with the least amount of tractions get the most power. Suck becase that wheel might be on ICE or sand and you are stuck
  11. Dec 19, 2008 at 7:22 PM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    Really? Has no one else responded w/ the answer to this or am I just reading wrong? Unless you have a diff locker that is engaged your axle is an open differential. That means that the power goes to both wheels unless there is a variance in traction between the two rear wheels. If your left tire is on ice, etc. and the right on pavement, the left will spin. If your right tire is on ice, etc. and the left on pavement, the right will spin. The power goes to the wheel with least resistance. It's all to aid w/ turning smoother (the inside rear tire will not receive as much power as the outside tire, so it will turn smoother).
  12. Dec 19, 2008 at 7:25 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    you can lead a horse to water but you can't make em' drink
  13. Dec 19, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I felt the 2 links I provided gave a clear explanation on how it works.
  14. Dec 19, 2008 at 8:03 PM
    DefyInertia
    Nate
    NorCal
    they did....
    so can anyone explain why it's usually the front left and the back rear that get get the most power or am I just making that up?
  15. Dec 19, 2008 at 8:33 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    LOL i thought this would be the end! haha oh well...
  16. Dec 19, 2008 at 8:41 PM
    dustinuhls
    Manhattan, KS
    2015 TRD Sport 4wd
    I actually didn't read your link until now, but I just figured this was something everyone knew already. I know this site is to help people out (I've also had some dumb questions later revised) but I thought most people knew there is not a "one wheel drive" truck. Sorry if I offended anyone, but I thought this was common sense stuff.
  17. Dec 20, 2008 at 6:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its because of the way the ring gear and planetary gears are in the Tacoma axels.
  18. Dec 22, 2008 at 6:09 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Its just the way it works and because the Right side is lighter! EX. Gastank and Driver on Left side.! :)
  19. Dec 22, 2008 at 6:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It has more to do with the location of the ring gear in the "pumpkin".
  20. Dec 22, 2008 at 6:33 AM
    PrezidentRedz
    Redz
    Owings, MD
    True, depends on the situation your in. but in almost any situation the lighter wheel, or wheel on a softer surface is going to spin, wasn't saying you were wrong...:D
