2 or 3” lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KingDaddy, Jan 11, 2024.
  1. Jan 11, 2024 at 5:11 PM
    KingDaddy
    KingDaddy [OP] New Member
    Daniel
    Connecticut
    2023 Toyota Tacoma TRD OR DCLB A/T
    I have a 2023 Tacoma ORLB… been very interested in getting a lift and tires… nothing too crazy 2-3” lift… any reasonable kits out there? I see tons of set ups just not sure what to get. Tia
  2. Jan 11, 2024 at 5:21 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    what’s your budget? Recommend searching the forum a bit
    Chew, Mully and 71tattooguy like this.
  3. Jan 11, 2024 at 5:25 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    2” keep things happy.
    Fitz235, Chew, Mully and 1 other person like this.
  4. Jan 11, 2024 at 5:34 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    See my sig.
  5. Jan 11, 2024 at 5:35 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Simply put 1-2" is best. But goals and budget play a huge roll into the how and why.
    71tattooguy and Chew like this.
  6. Jan 11, 2024 at 5:36 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    71tattooguy likes this.
  7. Jan 11, 2024 at 5:37 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Depends on what you want to do. Regardless. Keep it under 3”. You can start with Bilstein 5100 or 6112’s. 1 - 1.5 inch block in the rear if on a budget.
  8. Jan 11, 2024 at 5:52 PM
    KingDaddy
    Daniel
    Connecticut
    I hear a lot about the bilsteins…i hear people do 6112 in front 5100 in back…I wouldn’t go more than 3”…. Idk what’s a decent budget for this wouldn’t want to go to crazy maybe 2k or is that unrealistic? I would need tires too
  9. Jan 11, 2024 at 6:08 PM
    rnish
    Tacoma 2nd gen
    $200 x 4 tires. Mounting, bal, tax, alignment. You are over $1000.
    RIX TUX and KingDaddy[OP] like this.
  10. Jan 11, 2024 at 6:18 PM
    Veet-88
    And we're saying 3" is alot. You end up losing alot of ride quality increased maintenance on cv axles lots of potential till for vibrations.
    I had my truck at 3" at first to help compensate for spring sag and the extra weight of my bumper and winch so it would ideally rest at around 2" all said and done. And I personally would never want to run that much lift again.
    There's other aspects to the lift to consider aswell. Potential for front diff vibrations caused by the clamshell needle bearing or angled spacers/carrier bearing spacers to get that rear drive shaft inclined to reduce vibrations. Going to a 6112 you may have to do uca's to clear the 2.5" shock body.
    Then there's mention of tires, staying stock size? 32" 33" 35" ? These goals all play into what direction is best do you want to push the offset of the wheel for a wide look aswell.
    So for the best advice from all. I would outline use (street queen, weekend warrior, light wheeler etc...) tire size goal then lastly budget.
    I think a link to tinkerers videos may have been posted already if not look up yinkerers adventures on YouTube and watch his videos on Toyota ifs for a better understanding on what your going to affect with a lift.
  11. Jan 11, 2024 at 6:22 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
  12. Jan 11, 2024 at 6:24 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Keep it stock, because stock is cool.
    If you really want to lift your truck, do lots of research and do more research.
    When you have the funds for the lift you want, pull the trigger.
    Good luck with your truck.
  13. Jan 11, 2024 at 6:27 PM
    KingDaddy
    Daniel
    Connecticut
    yea I have some more research to do I’m not that well versed about all the other things that can be affected… I’m going for more the look but definitely want to do some off roading… maybe 33” tires that a popular tire with the tacomas I see.. the main thing is I want no custom fab work, cutting, or trimming. So I’d rather add a lift to get the aggressive tire look. I hear lots of negative things about spacers that seems like the cheap route I don’t want worse to happen from taking a cheap route
  14. Jan 11, 2024 at 6:46 PM
    TacoManOne
    Paul
    Liberty Lake, WA
    Big tires are heavier and eat gas mileage are more expensive ride worse…
    Chew likes this.
  15. Jan 11, 2024 at 7:00 PM
    Veet-88
    So I'll give you some food for thought that might really simplify things.
    33" can be looked at a few different ways.
    255/80r17 tall skinny
    Virtually no modifications to fit on stock may have to remove chin spoiler and mudflaps.
    285/70r17 the not quite 33 but most common size
    Generally ran with a 1-2" lift adjustable uca and custom alignment required to clear without a cmc pending wheel offset minor plastic trimming will be required at a minimum
    33x12.5 not common amongst tacoma owners from what I see
    Just get ready to start cutting
    265/70r17 32" honestly best size for these trucks
    Best availability in non LT rated tires best balance of MPG to performance. Generally no rubbing besides mud flap pending wheel offset.
    With all the changes I have made I miss my truck on a 0 offset wheel and a 265/70r17. It had a good stance reasonably agressive look still went everywhere I needed it to and required the least work. If I still drove my truck day to day I would revert back to that set up.
    Wheels tires and skids is where I would start over a lift.
    17x9 +1 265/70r17 duratrac stock suspension
    Current set up next to a stock offroad with 265/75r16 tires
    I'm on 2ish" lift front and rear 295/70r17
    And that thing has followed 90% of the places I have gone.
  16. Jan 11, 2024 at 11:33 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    welcome ........why do you want a lift?
    Chew likes this.
  17. Jan 12, 2024 at 8:56 AM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    3.50 lift with 20x12 and 305/50r20
  18. Jan 12, 2024 at 9:21 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
  19. Jan 12, 2024 at 9:29 AM
    AK Dudeman
    AK Dudeman Well-Known Member
    DCBLB OR MGM 22
    2”-1” 265/75/16.. 0° Offset. Still happy
    -Rorschach-, ricco333 and 71tattooguy like this.
  20. Jan 12, 2024 at 1:37 PM
    Sparkle_Tooth
    Sparkle_Tooth Well-Known Member
    East TN
    2020 TRD PRO (Magnetic Gray)
    ICON Stage 9 BFG KO2 285/75R/16
    Here's some things to keep in mind. Adding a lift is somewhat of a slippery slope, but well worth it in my opinion as I never leave my vehicles stock (Thats just me).
    Whatever you do, DON'T cheap out on this because when it comes to lifts, you do get what you pay for most of the time.
    • If you are going to keep your stock wheels expect to pay about $1300 - $1500 on a 285/75/16 or 285/70/17 tire for set of 4 (mount, balanced, alignment)
    • If you want custom wheels add about another $800 - $1400 based on your preference of wheel.
    • Most folks go for Bilsteins for an entry level but decent lift (And yes you heard correct, NEVER go Spacers despite what anyone says. Staying stock would be better)
    • If you want to stay with the Stock tire size then going with a 1 or 2" lift would be fine although may not have the aggressiveness you are looking for
    • There are many lift options out there (Dobinson, Dirt King, Bilstein, Toytec, King, Icon, Fox, etc). Personally I went with an ICON stage 9 which comes with the rear leaf pack (I needed that due to the weight of a Cap, and Decked drawer system). Of course you may want to consider a leaf pack with your lift since the stock leafs are total garbage and will flatten out if they havent already. ICON has a lot of good offerings in different stages. The stage 9 is overkill for most people but I love it and the ride is far better than stock I can tell you that for sure.
    • You will want to get an ECGS needle bearing eliminator bushing because your needle bearing will start grinding almost immediately (no big deal though to replace especially if it is done during the lift install)
    • All that said you can expect to pay anywhere from $2000 - $7000 for a decent lift and having someone install it for you (not including the tires mentioned above).
    TS4x4 and Stone.taco like this.
