2" or less front diff poll
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 02Duck, Jan 1, 2020.
How many with lifts 2" or less have had to or have put in the ECGS bushing?
  1. 2" lift or under no problem still running stock bearing
    35 vote(s)
    66.0%
  2. 2" lift or under replaced the bearing with ECGS bushing
    18 vote(s)
    34.0%
  1. Jan 1, 2020 at 5:18 PM
    02Duck
    02Duck [OP] manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Wanted to ask the question as a poll about the sometimes random issue of the front diff bearing. Really looking to see what people have experienced with a 2" or less lift.
    boston23 likes this.
  2. Jan 1, 2020 at 5:19 PM
    tcjacado
    tcjacado Well-Known Member
    Replace it either way.
  3. Jan 1, 2020 at 5:21 PM
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    Agreed. Complete 3rd and front clamshell just ordered from ECGS (5.29s baby!) and first thing I did was make sure the bushing is in there. I’ll send my cores back with that pos needle bearing lol
    IMO, Toyota knows it’s an issue and has a TSB for it. If that isn’t enough to replace it on a lifted truck, I don’t know what is. It’s barely $50 - take care of it or deal with the vibes, howls, and at worst - destroying your front diff when the needle bearing goes bye bye
  4. Jan 1, 2020 at 6:34 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Just replace it. It really isn't that big of deal if you are already lifting. I replaced mine because I know me. I would be mad and lazy angry if I had to take apart my front end to do something I should have done anyways.
    In the other thread about this, it's around 50/50 on replacement.
    My second gen pro suspension gave me right at 2" of lift.
  5. Jan 1, 2020 at 6:35 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    A Poll for a $60 bushing?!?!?
    Either you’re mechanically inclined or not. If you’re not pay someone to do it, if you are well it’s $60.
    (You Paid or are paying off a ~$30,000 truck.)
    It’s 2020 day one - either I’m trolling or you’re being cheap. Hahah Happy This Year!
    Superdave1.0 and DevilTaco4 like this.
  6. Jan 1, 2020 at 9:12 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    This is an understandable poll but I don't think you're gunna get what you're looking for.
    Seems like lots of people put the bushing before having symptoms so they won't know if their bushing would've failed or not
  7. Jan 1, 2020 at 9:20 PM
    tcjacado
    The reason being, why pay for 2 times the labor. If you are diy then it's just time taking it all apart again.
  8. Jan 1, 2020 at 9:22 PM
    Dr. Emmett Brown
    Exactly. I think OP wants to know if he/she should do it, based on the odds of it failing after the lift.
    tcjacado[QUOTED] likes this.
  9. Jan 1, 2020 at 9:25 PM
    tcjacado
    About 60 percent fail after 1 inch or more of lift. That's a ball park from my readings. 30 percent I would say last a few months to a year after a lift.
    SpeySquatch likes this.
  10. Jan 1, 2020 at 9:28 PM
    Dr. Emmett Brown
    So that means 90% fail, period which doesn't make sense because I've never heard of people here in Hawaii changing this bearing out or anyone having problems. I changed mine out to rule out a noise I was hearing and it turned out my bearing was fine after a year of driving on the 2.5" lift. Still have my bearing in my back seat cubbyhole too lol
  11. Jan 1, 2020 at 9:34 PM
    tcjacado
    As I said, just a given estimate from my readings. Definitely not accurate. Most don't even take the gamble just like you.
    JoeCOVA likes this.
  12. Jan 1, 2020 at 10:19 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    I got 2 inch lift 1 inch diff drop 48,000 miles still running the stock bushing the truck left the factory with no issues to date.
  13. Jan 2, 2020 at 12:35 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Not for me I lifted, and then felt the vibes afterward. Had to re do all that work on the driver side to pull the axle and change the bearing. Also had to get another wheel alignment. I didn't notice the bad vibes right away. Noticed it weeks after installing lift.
  14. Jan 2, 2020 at 1:47 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I did it as prevented maintenance, because I knew sure as hell I would get a vibration. Luckily I didn't get any.
  15. Jan 2, 2020 at 7:32 AM
    Dr. Emmett Brown
    That's why I wrote "lots" not "all". I didn't have vibrations after lifting 2.5" either.
    71tattooguy likes this.
  16. Jan 2, 2020 at 7:58 AM
    02Duck
    This is why i thought i poll would be interesting. It's not perfect but should be better than the alternative. I'm leaning towards changing it but this isn't just for me. It be nice to have feedback from people with actually experience counted up not just reading one thread here and there and then assuming.
    Thanks to everyone for answering.
    Superdave1.0 likes this.
  17. Jan 2, 2020 at 8:12 AM
    Superdave1.0
    SoCal
    I don't think a lot of people change it as preventative measure. Especially when counting all Tacoma owners out there that are lifted and don't even frequent this website. Most people don't know what this bushing is or does.
  18. Jan 2, 2020 at 8:20 AM
    Dr. Emmett Brown
    Mother of God. Let me rephrase this.
    This poll has nothing to do with the other people that know nothing about anything. This poll is for the users of tacomaworld who under my observation a lot of the time preventatively change out the bearing before any symptoms occur. Therefore not knowing if the bearing would have failed to begin with. I am one of those people as are lots of others.
    There is another thread that has exactly the same poll as this.
  19. Jan 2, 2020 at 8:24 AM
    tcjacado
  20. Jan 2, 2020 at 8:30 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    No vibes here, stock needle bearing.
    Fox 2.5 at slightly over 2" from stock.
    265s.
    02Duck[OP] and 71tattooguy like this.
