2 other alternator options for our 1st gen tacoma's with 5VZ-FE's
Discussion in '1st Gen. Tacomas (1995-2004)' started by sunnyjay, Dec 14, 2022.
  1. Oct 6, 2023 at 4:42 PM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    Ok thanks!
  2. Oct 6, 2023 at 5:49 PM
    semco-inc
    DFW & ATW
    Ho
    How did you resolve the pulley mismatch for the Denso -0140?
    thanks,
  3. Oct 8, 2023 at 10:41 AM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    Pulled an alternator from a 2001 in the junkyard
  4. Oct 15, 2023 at 10:22 AM
    sunnyjay
    sunnyjay [OP] Member
    Wow, love that more research has gone into these alternator options. Now that there is a cross reference to a similar denso alternator too.
    One thing with these Denso alternators, the parts are not special. The brushes/holder, bearings, rectifier bridge, regulator are shared across a lot of their alternators.
    Thank you all for the additional info.
  5. Sep 26, 2024 at 8:45 AM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    Regulator advise.
    Had my "New" Denso High output Alternator die after 3 months. Battery was also bad so possible one killed the other.
    Had the unit checked at Autozone and confirmed bad. I have tested each component separately that i can check other than the regulator. (Don't have that equipment) Assuming it is bad.
    Can anyone advise where to get a new 1126000-3400 regulator? I can find used ones but few new units that look the same but do not reference that Denso part number. Not sure if they are all the same or not. Closest i have found are the ARE6057 or IN452
    TIA.
  6. Sep 27, 2024 at 6:38 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I'm also interested in this. A new regulator from Toyota costs more than a whole reman alternator.
  7. Sep 27, 2024 at 6:50 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've been getting regulators from eBay, but where you live there's actually an alternator rebuilder in Mesa that can get you parts on the spot. I had mine rebuilt there when I was still in AZ, I'll figure out where that place was.
    Kiloyard[QUOTED] likes this.
  8. Sep 27, 2024 at 7:01 AM
    Speedytech7
    Kiloyard likes this.
  9. Sep 28, 2024 at 7:21 AM
    phoforbreakfast
    phoforbreakfast Well-Known Member
  10. Oct 9, 2024 at 10:27 PM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    Anyone know if the Denso Alternators here had the pulley shaft size problems that the -0140 did?
    I'm looking at installing the -6420 into my 3.0 4runner. Has the same round plug so no regulator swap required. Should be a nice easy upgrade
