2 post lifting tacoma equipped with air springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Feb 3, 2015.
  1. Feb 3, 2015 at 12:25 PM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    would the air springs break if the dealer lifts the truck up by the frame with their 2 post lift?
  2. Feb 3, 2015 at 12:30 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Do you mean air shocks or air bags?
    I don't see how it would matter for either. I lift my truck all the time, the springs only allow the wheels to drop a short difference.
  3. Feb 3, 2015 at 12:31 PM
    koditten
    Kirk
    Central Michigan
    Ha, ha, I just remembered my sig pic is of my truck with the wheels just off the ground. You can see how far the wheels drop when on a lift.
  4. Feb 3, 2015 at 1:24 PM
    magnum922
    Air bags.
  5. Feb 3, 2015 at 1:27 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    The bags can be damaged by over extension. If you have cups instead of the regular style mounts that will alleviate the problem, if not there is the potential for damage.
  6. Feb 3, 2015 at 2:17 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Deflate the bags before lifting, as per Firestone's instruction. The risk with the bags inflated to higher pressure is that the shock and mounts will not be strong enough to limit extension.
  7. Feb 3, 2015 at 2:38 PM
    Pigpen
    Dan
    Northwest Montana
    That
  8. Feb 4, 2015 at 7:16 AM
    magnum922
    I've decided to order the daystar cradle mounts with it so I don't have to worry about suspension travel. Thanks all.
