2 problems i would like to know how to fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rburdeaux, Mar 12, 2017.
  1. Mar 12, 2017 at 12:19 AM
    Rburdeaux
    Rburdeaux [OP] Well-Known Member
    2004 Double Cab Prerunner
    1st problem: my driver side rear door lock wont lock or unlock with the button, i have to do it manually.
    2nd problem: the light on the roof in between seats does not work. (interior) like the dome light.
    are there any previous threads or helpful insight from anybody thanks!
  2. Mar 12, 2017 at 12:27 AM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    1 check relay
    2 replace bulb
    Rburdeaux[OP] likes this.
  3. Mar 12, 2017 at 12:28 AM
    Rburdeaux
    what is the relay?
  4. Mar 12, 2017 at 12:32 AM
    nickj604
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Take your truck to a mechanic.
    A relay is a electrical switch that allows a little current to activates a big current. It sounds more complicated then it is. Use Google and try searching it. I dont know if you truck has 1 for each door lock. If it does you could just switch the 2 to see if that's your problem. Ha e you tried replacing g the battery in your fob ?
  5. Mar 12, 2017 at 12:33 AM
    Rburdeaux
    i dont have a fob, just a normal metal key.
  6. Mar 12, 2017 at 12:34 AM
    Rburdeaux
    i'll just take it to a mechanic
  7. Mar 12, 2017 at 12:36 AM
    nickj604
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    So you have power door locks in the cab but no fob ?
    Remove the door card and check the contacts on the lock see if they have green fuze on them if they do try cleaning it off. If that doesn't fix it try replacing it. The servo could be toast
  8. Mar 12, 2017 at 1:41 AM
    Rburdeaux
    ooops power locks. sorry my bad. when i put the key in and turn to lock everything, everything locks but the rear driver side door.sorry ive been drinking.
    ajm likes this.
