2 Questions
Discussion in 'X-Runners' started by cbrbob, Nov 2, 2010.
  1. Nov 2, 2010 at 3:27 PM
    cbrbob
    cbrbob [OP] Member
    Bob
    Central, NJ
    06 X-Runner
    Anyone found adjustable upper control arms for the X-Runner?
    Would like to be able to move the top of the tire outward to gain some camber back (truck is lowered).
    Also anyone found stainless brake lines for the rear of the XR?
    If so for either, please PM me the part#s and where you got them.
    Thanks!
    P.S. I would appreciate not having posts like "just put on rear disks" or "use the whole DJM kit". Thanks!
  2. Nov 5, 2010 at 10:01 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    are you running stock control arms? if you want to go anywhere past 3" up front you need the DJM upper and lower control arms to get it back to stock spec. the DJM control arms are the only control arms out there at the moment for these trucks. you can only go 1.75" or so up front without having camber problems, and the lower you go from there the worse it'll be.
    how much are you lowered up front? and what kind of drop do you have?
  3. Nov 6, 2010 at 5:05 AM
    cbrbob
    cbrbob [OP] Member
    Bob
    Central, NJ
    06 X-Runner
    Stock arms, thats why I am looking for an adj. upper, to get +camber back.
    I have the SOS kit 1.5". That with the TRD SC, added weight and dropped the front more. I don't want more lowering, I want less neg camber.
    I know about the Sittin Sic higher rate stock coils, which would do the trick. But I get no response from them. That would be a good fix.
  4. Nov 6, 2010 at 2:20 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    with the SOS 1.75" kit you should be able to get it into stock alignment specs no problem. where'd you get your alignment from? alot of the big box stores (goodyear, firestone, sears) don't have the best alignment techs, so your best bet would be a local specialty alignment shop that is used to dealing with modfied suspensions.
  5. Nov 7, 2010 at 4:27 AM
    cbrbob
    cbrbob [OP] Member
    Bob
    Central, NJ
    06 X-Runner
    Local alignment shop, yep. In fact the guy there has a XR. Look I'm not shooting in the dark on this one. I know what I'm doingand wy it's out. I just don't have all the answers to get it back.
    The truck WAS in alignment. Added the TRD SC, now it's out and just beyond being aligned.
  6. Nov 7, 2010 at 9:23 AM
    speckdzl4shzl
    speckdzl4shzl Tundy cruisin'
    Thornton, CO
    07 Tundra
    the S/C won't add that much weight that it will drop your truck out of specs. they come from the factory with S/C's, Toyota thought of those things when they designed it...
    might be your SOS kit. that's not the best way to lower these trucks.
    in any case i've seen of tons of dudes on XRU with the SOS kit and S/C's and none of them have had alignment issues. if anything the negative camber will help the handling of your truck.
    i'm at a -1.7 on each side and don't have any uneven tire wear. i rotate every oil change and keep an eye on the inside of the tires because of it but for the past 10k with these tires they're still perfect (Nitto NT555's).
    you might want to go to another alignment shop just to check. you never know.
    check your tie rods. if they look like mine \ / you won't be able to fix them other then going back to a stock setup. there's no bump steer kit for our trucks....
  7. Nov 8, 2010 at 6:28 AM
    cbrbob
    cbrbob [OP] Member
    Bob
    Central, NJ
    06 X-Runner
    Wow, you guys are all full of good news.
    No reality check here, huh.
    It was barely in spec prior to the SC, now it's out, check.
    I have never heard of an 05 tacoma with a SC from the factory.
    You guys like a lot of -camber, thats nice, it wears tires out, I know.
    Will it help handling, sure if all you do is corner hard. I put lots of miles on, would like to keep the 285s from wearing out in 10k miles so I like the camber close to zero.
    If you check XR, you would have seen my involvment for a quality bump steer kit, new quality front struts etc.
    It seems many are just in it for looks and some of the better solutions, like the DJM, are 3", too much for where I live. And I work on my own truck so getting a jack under it is an issue with 3".
    As far as waiting for Shane, it seems thats all anyone does lately, is wait. Sad, I would like to have those coils.
    As far as the SC, Unless you have picked up all the boxes it came in........you would know.
    Thanks for the SSlines info.
  8. Nov 8, 2010 at 7:46 PM
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    Wouldnt think adding a S/C would throw it out..
  9. Nov 9, 2010 at 7:03 AM
    speckdzl4shzl
    Thornton, CO
    07 Tundra
    many people have got their 1gr taco from the factory with a supercharger on it.
    never seen/heard of a bumpsteer kit on someones truck. all just "we need one talk"
    been on these boards for over 3 years and never heard anyone have that problem.
  10. Nov 9, 2010 at 11:36 AM
    05h0twheels
    05h0twheels New Member
    o.c.
    05x
    many.
    custom make one, a bumpsteer kit
  11. Nov 9, 2010 at 12:39 PM
    05 X-Runner
    Brett
    X-Runners don't come from the factory with superchargers,the stealership will install one after u get the truck
  12. Nov 9, 2010 at 7:03 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    toyota does not install chargers of any kind at the factory. they may be dealer installed but thats just so they can charge you a arm and a leg for it
  13. Nov 9, 2010 at 10:57 PM
    05 X-Runner
    Brett
    He did, Read top line post #11
  14. Nov 10, 2010 at 5:58 AM
    cbrbob
    cbrbob [OP] Member
    Bob
    Central, NJ
    06 X-Runner
    Well this thread has been jacked enough to say
    ADMIN PLEASE LOCK IT
  15. Nov 10, 2010 at 8:58 AM
    speckdzl4shzl
    Thornton, CO
    07 Tundra
    i meant dealership. come on guys. bunch of amelia badelias here.
