2 Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coopjl, Dec 2, 2016.
  1. Dec 2, 2016 at 2:40 PM
    coopjl
    coopjl [OP] Well-Known Member
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    ARB Deluxe bull bar ARB Fog lights ARB Driving lights 24" Vision X Light bar ARB Rear locker w/4.56 ARB Front locker w/4.56 ARB Compressor Warn M8000# winch OME HD suspension CBI rock sliders CBI Trail Rider rear bumper with tire carrier and fuel can carrier Lear Topper with wilderness package TRD Matte Black Wheels SlimLine FrontRunner II Roof rack
    1). What size TORX Bit is required for the bolts holding the bed to the frame?
    2). I occasionally hear a grinding noise just before my transfer case shifts into 4H when moving. Is this a transfer case issue, or is it an issue with the electronic actuator which moves the transfer case rod?
    Many Thanks!
    Jeff
  2. Dec 2, 2016 at 2:41 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
  3. Dec 2, 2016 at 2:56 PM
    Pigpen
    Dan
    Northwest Montana
    The noise is probably the chain engaging your 4 wheel drive. It works just like a bicycle chain shifting gears.
  4. Dec 2, 2016 at 3:12 PM
    coopjl
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    Jake, I don't understand.
    Siesta, Thanks. Does that mean I need to tear into the xfer case and replace the chain?
  5. Dec 2, 2016 at 3:20 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I think hes saying its size is T55
  6. Dec 2, 2016 at 3:25 PM
    jake72
    Jake
    N.E. PA
    Bed bolt size t55
  7. Dec 2, 2016 at 3:26 PM
    coopjl
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    Yep, figured that out about 5 seconds after I hit the reply key...feeling like a dummy right about now.
    Where did you get your kit?
  8. Dec 2, 2016 at 4:39 PM
    Pigpen
    Dan
    Northwest Montana
    I've never heard mine grind. It will click, or even bang depending on how much pressure is on it when it shifts. The smoothest engagement will be when rolling in a straight line without throttle or brake applied - rolling fast is smoother than slow. Turning, braking, or accelerating are sometimes unavoidable when engaging 4wd. Shifting into 4 doesn't usually go smoothly when stopped.
