2" rear lift, shock bottoming out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frankwarren, Apr 18, 2025.
  1. Apr 18, 2025 at 11:07 AM
    Frankwarren
    Frankwarren [OP] New Member
    Frank
    2020 Toyota Tacoma trd sport
    Hey
    I put a 2" lift aal in the rear, now my shock is bottoming out when it extends.
    Can I put tundra shocks in my tacoma as they are a little longer from what i researched.
  2. Apr 18, 2025 at 11:31 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    The shock is bottoming out or over extending? Post some photos so we can provide input. Tundra shocks are valved for a heavier vehicle(tundra weighs more than tacoma) so they will likely be very stiff, IF they even fit.
    Chew likes this.
  3. Apr 18, 2025 at 11:42 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    They won't, without modification..
    Chew and Dorf510[QUOTED] like this.
  4. Apr 18, 2025 at 11:43 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Not without modification. Just pick up a set of 5100's for the rear for around $280. Or if can spend a little more you can get 5160's or fox's cheaper 2.0
    Chew likes this.
  5. Apr 18, 2025 at 5:40 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Maybe you need bigger bump stops??
  6. Apr 18, 2025 at 6:14 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    The problem is he's topping out, not bottoming out. If he wants to continue running his current setup as is, he'll need to strap the rear. The oem shocks don't have enough extended length to accommodate the added lift.
    Tocamo[QUOTED] likes this.
  7. Apr 19, 2025 at 4:16 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    5100's are only good for extra 1" 5125's or 5160's will work. There is other brands as well, just need to research.
  8. Apr 19, 2025 at 6:51 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    OP did not specify what model Taco he has or the rear shocks currently on it, to get current specs.
    Stock Offroad rear shocks on 3rd Gen are the same extended length as 5100 rears.
    Bilstein 5125 or 5160 are longer with similar compressed spec. I have Fox 2.0 with comparable specs for the additional length.
    Tocamo likes this.
  9. Apr 19, 2025 at 9:29 AM
    Frankwarren
    Frank
    Sorry for late replys guys but yes my shock is extending out and banging when suspension is extended fully during off road driving. Ordered 2 shocks last night to compensate for the 2" lift.
    Anyone want to buy 2 new oem shocks for a tacoma up here in Canada? Lol.
    Tocamo likes this.
