2 Satoshi Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChamYota, Dec 10, 2011.
  1. Dec 10, 2011 at 12:28 PM
    ChamYota
    ChamYota [OP] Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Hello all! I have but two questions so here they are. Below you will see my progress on my grill. I've already sanded 60 grit,220 grit,400 wet sand and everythings all cleaned up. In the picture i have a LITTLE bondo still on there.
    1. Can i paint over the fiberglass as is, or do i need to cover it up with bondo/hardner. Its the only thing stopping me from finishing it up today.
    2. How would i prep the metal mesh for paint? Im painting it black of course.
    All beneficial responses are welcome! :D
  2. Dec 10, 2011 at 12:35 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    HomerTaco told me you can get some degreaser and clean it off and spray. That just leaves your first question.
  3. Dec 10, 2011 at 12:38 PM
    ChamYota
    Cam
    Ahh thanks i was thing the same. One down :D
  4. Dec 10, 2011 at 1:03 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    I'd skim coat the fiberglass and hit it with some fine grit before Id paint it.
  5. Dec 10, 2011 at 1:15 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    I'd hit it all with an even coat of filler primer.
  6. Dec 10, 2011 at 1:42 PM
    ChamYota
    Cam
    Done and done. Its very smooth to the touch
    Got that too! About to go do it now!
    Thanks guys! :D
  7. Dec 10, 2011 at 1:54 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Lets see some pics when you finish up!
  8. Dec 10, 2011 at 2:19 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Guess you finally decided to fix it! Looks much better now man.
  9. Dec 10, 2011 at 2:51 PM
    ChamYota
    Cam
    :mad:
    This damn can is running off. :( Its cold outside. i got one coat on but ill have to wet sand it off. O.- so... gay. :(
  10. Dec 10, 2011 at 3:53 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    so your doing the inside white? Should be interesting! I thought about doing mine that way...tuned in to see how it turns out.
  11. Dec 10, 2011 at 4:28 PM
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    I would say slow down a little. Anything you can see when it is primed will show up 10 times worse when you paint. Use 3m green tape if you don't want anything to bleed over and be careful with your tape lines. Sharp or overlapping tape lines will create a ridge that is a PITA to sand out. Multiple light coats will get you a lot farther than heavy coats. Temperature is important, so you might have to heat up the material a little bit. Good on ya for tackling it. Looks easy but it is actually a big job.
  12. Dec 10, 2011 at 4:36 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    If you are doing that outside, wait for a warmer day. It's way too cold for the primer and paint to cure right.
  13. Dec 10, 2011 at 4:38 PM
    ChamYota
    Cam
    lol thats what the flash did. Its actually gray "filler primer". :eek:
    I see what you are saying. I've never spray-canned anything before. I waited till 5:00 when it was around 50ish. ill try again tomorrow.
  14. Dec 10, 2011 at 4:46 PM
    congicus
    congicus Well-Known Member
    mike
    Tucson
    2011 4x4 SR5
    If you are like me and have to get this done now :D get some space heaters and heat up the garage, unplug them before you paint but it has worked for me in the past
  15. Dec 10, 2011 at 4:49 PM
    ImpulseRed008
    Susan
    SC
    practice on a piece of cardboard or an old can or bottle. When you are doing the final coats, you don't want to mess up.
  16. Dec 10, 2011 at 5:18 PM
    ChamYota
    Cam
    Ill set up my dad's kerosene heater and do that tommorow. It will be on my truck, it cannot look tacky. :eek:
  17. Dec 10, 2011 at 5:35 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    correct.
    everyone's advice has been spot-on.
    best thing I can tell you is this:
    Take Your Time!
    Looking forward to the result.
    :popcorn:
  18. Dec 10, 2011 at 5:42 PM
    ChamYota
    Cam
    Thanks for the advice everyone! I've been sooo anxious to get it done, ive been holding it off till i had enough money to get all the supplies at once. I suppose ill have to do it all in stages. First, making sure i know how to use a spray can. lol
  19. Dec 11, 2011 at 1:15 PM
    ChamYota
    Cam
    UPDATE:
    I decided today to not worry so much on the grill as it is December.. :(
    But i did make progress on the mesh side of the satoshi :D
    My mounting strategy: Epoxy!
  20. Dec 16, 2011 at 2:13 PM
    ChamYota
    Cam
    Update time! I got the grill primed right this go found and I need to fill in a couple cracks with bondo next weekend. On another note I have the grill mesh primed and painted! :D pics will be up when I get back to my laptop.
