2 sets of TPMS with TechStream??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vssman, Nov 7, 2014.
  1. Nov 7, 2014 at 2:57 PM
    vssman
    vssman [OP] Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Can 2 sets of TPMS sensors be programmed into the ECU with the TechStream software? How? I see how to replace the 4 sensors with new codes but not how to save the existing and add 4 more. Also is there a factory alarm function in the ECU that can be activated with the software? I recall reading someone activated it but I can only find the immobilizer function and not an alarm.
  2. Nov 7, 2014 at 6:50 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I know that on my '06, one can program a second set of sensors with a Snap-on scan tool, but I'm not sure about how to do it with Techstream as I gave up trying to get mine to work with Windows 8.1. You still need to manually select which set when swapping winter / summer wheels, if that's what you're up to.
    The newer TPMS systems may be different, but I'd bet there is a way to do it with your '13
  3. Nov 7, 2014 at 6:58 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Yup, that's exactly what I'm after. I run studded snows on the stock steelies and have aftermarket wheels for the summer. It would be handy to have the codes programmed already. I have yet to figure out how to enter and save 2 sets. It certainly isn't inuitive.
    I run my TechStream on an old laptop the was going to be recycled running XP. Slow as molasses but it does the job.
  4. Nov 7, 2014 at 8:21 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I wasn't able to. It only allowed up to 5 sensors.
  5. Nov 8, 2014 at 4:31 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I've recorded the codes off the summer tires. Once I get the winter wheels on and have the light turned off, I'll be able to get those codes through the PC. It looks like I'll have to manually enter each set when I flip the wheels.
  6. Nov 8, 2014 at 9:50 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    When you select the TPMS module, there's a menu option on the left that'll show the current codes along with the current air pressure and tire temp. It also shows you the threshold pressure where it'll trigger the light.
  7. Nov 8, 2014 at 11:33 AM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    From the reading I've done on the forum, it is not possible to store two sets of TPMS codes in the computer of a Tacoma. IIRC other models (cars, I think) of Toyota can.
