2 sets of wheels/tires with tpms in both how to?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dean62, Oct 12, 2020.
  1. Oct 12, 2020 at 10:04 PM
    Dean62
    Dean62 [OP] Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    Is it possible to have 2 different sets of wheels with tpms in both sets and then reprogram after swapping them on a 3rd gen? If so can anybody explain how to do it? I have my stock wheels with street tires that I'd like to drive on normally then I just a set of wheels and tires for trails that id like to put tpms in before mounting and balancing if it's possible to swap between sensors without going to the dealer every time to have them reprogrammed to the truck
  2. Oct 12, 2020 at 11:10 PM
    Beachdog77
    Beachdog77 Well-Known Member
    Saskatchewan, Canada
    2019 TRD Sport
    I use the Ateq quickset to switch between summer and winter tires. It will read the codes of the tpms that are already in the ECU. You will need to manually enter the codes from the new tpms into the program. https://www.ateq-tpms.com/en-us/products/quickset-light-tpms-reset-tool/
  3. Oct 12, 2020 at 11:17 PM
    Dean62
    Jacob
    Florida Panhandle
    what sensors did you buy to use with this tool? Also where'd you buy the tool from and what'd you roughly spend? Trying to find good deals
    It also looks like you need another tpms tool is that true
  4. Oct 12, 2020 at 11:21 PM
    Beachdog77
    2019 TRD Sport
    I can’t remember where I bought the Ateq from or what I spent. I’ve had it for at least 5 years. Check Amazon. The tpms I picked up from my Toyota dealer.
