2" suspension lift, will -10mm offset rub? max tire size
Discussion in 'Wheels & Tires' started by Dbauer89, May 12, 2021.
  1. May 12, 2021 at 9:13 AM
    Dbauer89
    Dbauer89 [OP] Active Member
    Don
    2016 Toyota Tacoma TRD Sport
    Hey everyone,
    Just looking to purchase a rim with -10mm offset to push the wheels out a little. I have a 2" lift and I cant get a straight answer online if this will cause any issues with rubbing, I know that this also has to deal with the tire size I choose. If anyone can give me some guidance or recommendations on tire size and this offset it would be greatly appreciated.
    Bob1971 likes this.
  2. May 12, 2021 at 9:16 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Any tire wider than 265 will rub somewhere. You might need a CMC, you might just need to trim the finder liners. What tire size did you want to go up to?
    wi_taco likes this.
  3. May 12, 2021 at 9:20 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I have -12mm offset and went to 255/85/16 (33in tires) I just had to trim 1/2 inch on the inside of the fender
  4. May 12, 2021 at 9:21 AM
    Dbauer89
    Don
    Right now I just have stock tires.. Id like to go a little bigger to at least a 32"
  5. May 12, 2021 at 9:23 AM
    Jays19TRD
    Jays19TRD Well-Known Member
    Mine is rubbing with same wheels offset(-10) and 265/70/17 but need an alignment. Will post up results later on today. Suspension is Elka 2.5 and Camburg UCA.
    Dbauer89[OP] likes this.
  6. May 12, 2021 at 9:23 AM
    littlefish
    Hudson Valley NY
    You can fit a 32" (265/75R16) tire on stock wheels and stock suspension. You can also fit a 33" (255/85R16) on stock wheels and suspension. Anything 33" or bigger, wider than the 255 will need something cut or trimmed. I run the skinnies and personally love them. I haven't been convinced to go wider and deal with more fitment issues.
  7. May 12, 2021 at 9:29 AM
    Dbauer89
    Don
    ok. Now let me ask another potentially dumb question, does the rim width matter? The specs of the rim I'm looking at is 17x8.5, -10mm
    Sig Taco likes this.
  8. May 12, 2021 at 9:31 AM
    littlefish
    Hudson Valley NY
    I'm not the subject matter expert, I can't really give you a great answer on that.
    However, play around with this tool. Will really help you learn how all of the numbers impact one another.
    Dbauer89[QUOTED][OP] likes this.
  9. May 12, 2021 at 8:08 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Simple answer is yes.
    wi_taco likes this.
  10. May 13, 2021 at 7:30 AM
    tacomaboned
    tacomaboned Well-Known Member
    Georgia
    Silver 2012 Toyota Tacoma TRD Offroad
    265/65r16 is not anywhere close to a 32", that's like 29.5". 275/70r17, 265/70r17 and 265/75r16 are all considered 32"
  11. May 13, 2021 at 7:33 AM
    littlefish
    Hudson Valley NY
    You're right. I meant 265/75R16. I fixed my post.
  12. Aug 28, 2021 at 8:11 AM
    Tacoguy415
    Tacoguy415 Member
    2021 Trd Offroad 4x4
    what did you end up doing? I’m trying to figure out what tires to get for my gram lights
  13. Aug 29, 2021 at 12:23 AM
    Dbauer89
    Don
    Funny you ask, I just had 17x8” rims with -10mm offset and 275/70/17 tires installed. They definitely rub but not too bad. I just need to trim some of the plastic and think that will do the trick. Will keep you posted on what works
  14. Aug 29, 2021 at 12:34 AM
    lylefk
    lylefk Well-Known Member
    Maui, HI
    '21 4wd Cement Sport DCSB
    Nothing major
    My 265/70/17 rub a bit now and then on the oem mudflaps with 1.5” up front and some -10 Scs wheels. I’ll take them off once my sliders arrive. Fine to drive as is for now.
  15. Aug 29, 2021 at 1:59 PM
    Tacoguy415
    Tacoguy415 Member
    Do you have a lift? I’m getting anxiety lol because I ordered 285 70 17 nitto ridge grapplers
  16. Aug 30, 2021 at 2:15 PM
    Mods2Travel
    Mods2Travel Well-Known Member
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Level 8 MK6, 16x8, 6x5.5, +0 Offset Rims 285/75/16 (33") BFG KO2 tires 4.56 Gears from ECGS DIY bed/drawer slideout Bed Mounted Deep Cycle Battery/Fuse Box/Inverter/Isolator Yellow Wire Mod Rear Diff Breather Mod DIY Roof Rack Leer 180 Shell Bilstein 6112, Circlip #4 Bilstein B8 5160 Remote Reservoir Firestone Ride Rite 2407 Rear Suspension Airbags DayStar Cradles Camper Shell Radiator Fans for sleeping in warmer climates
  17. Sep 17, 2021 at 1:01 PM
    Dbauer89
    Don
    yeah I have 2” lift but I haven’t been able to get the new coil overs installed. I tried installing today using the weight of the truck and a hydraulic jack and couldn’t keep the top pin straight enough to go into the slot. Hoping the new shocks add a little more height. After trimming the plastic I’m still rubbing on the frame a little
