2 Trans blowing at 7k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doak110, Jan 26, 2016.
  1. Jan 26, 2016 at 12:06 PM
    Doak110
    Doak110 [OP] Well-Known Member
    Doug
    Howell , NJ
    2015 white Tacoma trd
    6in bds lift with Fox 2.5 factory coil overs and shocks Fuel rims 20x9 Toyo open country MT 33x12.50 Flow master cat back K&n cold air intake Bp fab grill 20in lightbar 2 3x3 Kc cubes 1.25in spider track wheel spacers HIDs headlights and fogs Red line hood struts Weather Tec mats
    So about 7 months back i was doing some playing around in the sand doing some doughnuts. notice my truck got a little more warm than usual. Soooo long story short stop to let it cool and started on my way home, thats when i notice my truck would end up shifting erratically. Between shits rpms would jump to about 4500 before kicking into gear. So i ended up taking it to Toyota being it only had 7k at the time. In the end they replace the trans and 10k later all good. still wonder what could have made it go so early in its life. well today i get a text from my buddy that lives in the next town over. (13 Tacoma trd offroad) He goes on to tell me over the weekend he was doing some doughnuts in the snow we just got and this morning as he was driving to school and he said his truck was shifting erratically (his truck only has 7k on it) now it has me thinking i didn't just have a odd defective trans that there is a bigger problem that most owners dont know about. especially when Toyota replaces it for free with little to no questions asked. Whats your guys opinion on this ?
  2. Jan 26, 2016 at 12:09 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Low on fluid from the factory could have something to do with it.
    Or wait, were the two tran(nys)blowing at 7 grand each or 3.5 grand each? That's an expensive blow.
    billybob50 and Arailt like this.
  3. Jan 26, 2016 at 12:12 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    When you make 150K trucks a year the odds are that some will have major failures like yours. Toyota accounts for the fact that some will fail and it sounds like they fixed your problem fairly easily. The transmission in your '15 has been in production for over a decade with over 1 million being produced. I think if there was a major engineering defect it would have been discovered by now.
  4. Jan 26, 2016 at 12:27 PM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    I think it's now normal to come from the factory a little on the low fluid side. That way when the warranty is up most likely the transmission will go unless you have Toyota do a fluid check. Then again, if you abuse the shit out of it, it'll go sooner!
  5. Jan 26, 2016 at 12:36 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Sounds like you both treat your trucks like shit imo
    billybob50 likes this.
  6. Jan 26, 2016 at 2:52 PM
    Doak110
    Doug
    Howell , NJ
    2 different trucks
  7. Jan 26, 2016 at 2:53 PM
    Doak110
    Doug
    Howell , NJ
    doing some doughnuts in the sand and snow.... dont really think thats treating it like shit
  8. Jan 26, 2016 at 2:54 PM
    Doak110
    Doug
    Howell , NJ
    yeah but 7k come on
  9. Jan 26, 2016 at 3:05 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    One thing to realize when you "play around" at low speeds is that there's also less air flow into the front of the truck. Heat is the enemy of any transmission. If you're spinning around in circles with the accelerator pegged to the floor, you're generating a lot of heat in both the engine and the trans while not a lot of air is flowing through to remove the heat.
    I think you should feel fortunate that Toyota had the good graces to replace the transmission under warranty. That's easily a $3000-$5000 repair.
  10. Jan 26, 2016 at 3:15 PM
    Boone
    Boone, NC
    Airbags deployed
