2 unrelated questions - slow tire leak and water in light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingston73, Sep 18, 2021.
  1. Sep 18, 2021 at 11:30 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I got new tires a week ago and one of them seems to have a slow leak. About 5 lbs over 24 hrs -ish. Should I give it time or take it back immediately?
    Also, took my fog lights out and then drove in the rain without the light bulbs in. Now one of them has moisture in it. Is this something I need to worry about or will it eventually just evaporate?
  2. Sep 18, 2021 at 11:36 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    If you want them to do it free if bring it back soon. Probably just a leaking valve stem.
    Open the fog and dry with paper towel or qtip soaked with isopropyl alcohol. Let dry and good to go.
  3. Sep 18, 2021 at 11:38 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    First, 5 lbs. over 24 hours is hardly a slow leak. Take it back immediately.
    As for the water in your fog lights, you need to dry it out. It will not evaporate on its own. And if you don't dry it out and slap the bulbs back in, they will probably fail in pretty short order. It's easiest to remove the whole housing, then bake in an oven at 100 degrees (F) or less for about an hour with the bulb opening facing up.
  4. Sep 18, 2021 at 12:14 PM
    jeminyned
    jeminyned Well-Known Member
    Jerry
    2013 4 Dr Black Tacoma TRD Offroad
    Seat Covers and just getting started!
    I have water in one of my fog lights and I got the bright idea to use a hair dryer on it. Haven't tried it yet, is there any reason why it wouldn't work?
  5. Sep 18, 2021 at 12:28 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    take tire back.
    water in fog light? do you have compressed air? blast some air into that headlight. or park the truck in the sun with the bulb out.
  6. Sep 18, 2021 at 12:31 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If it's not the valve stem, have them break the bead back down and put bead seal on both beads. It's kind of a like gasket sealer, it comes in a can with a brush built into the lid.
    Yes, take it back immediately. If you routinely run that tire low on air pressure, you'll quickly ruin it.
  7. Sep 18, 2021 at 1:04 PM
    Too Stroked
    Tom
    In theory, it should work. You're going to be there for a while though.
    jeminyned[QUOTED] likes this.
  8. Sep 18, 2021 at 6:10 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Not a slow leak, take it back. Steel or aluminum wheels? If aluminum, how corroded are the wheels?
