2" vs 3" leveling and alignment?
Discussion in 'Suspension' started by Rustyota, Nov 16, 2009.
  1. Nov 16, 2009 at 7:03 PM
    Rustyota
    Rustyota [OP] well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    Hi All. I'm a newbee here, so first, Howdy! I've got a 2nd gen. (08) DC 4x4 and put in the cheap-o 3" strut spacer leveling kit and don't like the alignment issues that have come with it. It was also higher than I expected (no, I probably don't know how to use a ruler!) and I've decided I don't really need/want that much lift. Wondering if a 2" would be much better on alignment or if I have to go the more expensive route with the Bilstein 5100s. I don't really want to (have the money to) do the UACs after spending so much on the truck!!!
  2. Nov 16, 2009 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 5100's would give a much better ride. And setting them on the 1.75" setting is much better on the alignment. Welcome to TW! :)
  3. Nov 16, 2009 at 7:10 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    Thanks! So, it seems to me that you'd have to realign each time you changed setting on the 5100s--is that right? My guess is you pick one, align it, then stick with it? Forgive my ignorance...
  4. Nov 16, 2009 at 7:16 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    Any other mods needed for the 5100s? And does the installation require a spring compression or anything? I had no trouble putting in the spacers, but not sure if the 5100s would be as easy. Any thoughts?
  5. Nov 16, 2009 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats correct.
    You need a spring compressor to install.
  6. Nov 16, 2009 at 8:22 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    Thanks for the info!! I think I'll do it.
  7. Nov 16, 2009 at 8:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help. Post pics when you get a chance. We all love pics :)
  8. Nov 16, 2009 at 8:37 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    Will do! I might even take some pictures of the truck! :D
  9. Nov 16, 2009 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! Thats what we like to see....
  10. Nov 16, 2009 at 8:51 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    Hey one more thought--is it fine to have the stock bilsteins in the back with the 5100s in the front?
  11. Nov 16, 2009 at 9:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, but the 5100's are a huge upgrade over the OEM ones...You wouldnt regret getting them for the rear too.
  12. Nov 16, 2009 at 9:08 PM
    Rustyota
    Central Coast, CA
    08 4x4 DC long bed
    More to think about... Thanks a ton. I'll post pics!!
  13. Nov 16, 2009 at 9:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep in mind, You can get all 4 5100's for under $300.00 from Downsouth motor sports.
  14. Nov 17, 2009 at 5:40 AM
    09Doright8126
    09Doright8126 Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    Thats the exact setup I have except I also got Eibach springs (instead of reusing the stock coils) and set the front Bilsteins at 0 and let the coils lift the front 1.6"
