2 way radio recommendation
Discussion in 'Off-Topic Discussion' started by 682bear, Sep 10, 2019.
  1. Sep 10, 2019 at 12:32 AM
    682bear
    682bear [OP] Well-Known Member
    West GA
    2006 SR5 DC and 2015 TRD OR DC
    I need a good set of 2 way radios... my 81 year old father enjoys walking in the woods behind his house... he walks 2 miles every day that the weather permits. There is no cell phone service there and he has no other way to call for help if he was to fall and hurt himself.
    I had bought a cheap set and tested them, (I don't remember the brand), but at the back of his property, about 1/2 mile from his house, the reception was unreliable... so I sent them back and ordered a set of Motorola radios. They were advertised as having a 25 mile range under perfect conditions. They were worse, with the reception disappearing completely at 600-700 yards.
    The property is heavily wooded, and sort of shaped like half bowl, with the front at the top of a hill and the center of the back line is in a creek bottom. Total elevation change is probably less than 50 feet. The farthest point being a little less than 1/2 mile from his house.
    Any recommendations on a good, reliable set of radios that will cover this? Preferably something light and easy to carry, of course.
    Thanks- Bear
  2. Sep 10, 2019 at 11:10 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Any objects like trees, rocks, etc will significantly reduce the range. Also, the higher the radio frequency, the more those objects will cause issues. The portable radios you've been testing are FRS/GMRS and operate at higher frequencies than, say, a portable CB radio. But a portable CB also operates at slightly lower wattage, and their antennas are less-than-ideal for the lower frequencies, so that may negate any advantages.
    There's only so much you can do without getting a license to operate more powerful radios. If you're not worried about cash, then you could try a couple of portable CB's, but theres a chance they may not give you what you need. Plus if you're near a highway you may not be able to find a consistent open channel.
    I am not even close to an expert, but there are a number of HAM folks on this forum, hopefully someone can speak up and tell you which brands hit that sweet spot and get the best range.
    whatstcp likes this.
  3. Sep 10, 2019 at 11:12 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Go get your GMRS license from the FCC. It covers you and your immediate family, I believe all it costs is $75 for 10 years. GMRS broadcasts at a higher power band than FRS, give you more range. However it's still limited without clear line of sight.
  4. Sep 11, 2019 at 6:32 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Get him a SPOT device or a Sat phone. RF communications can only do so much.
  5. Sep 11, 2019 at 6:57 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I like this, although you need a clear view of the sky for satellite, which may or may not be easy to do in his situation. I have a Garmin Inreach and it has worked extremely well. In either case though theres also a service fee.
    If you want the widest possible range of radios for a civilian setup and and an people that might be able to help, it'll hard to beat ham radio. A 2 meter (144Mhz-ish) radio can be had for $50 and depending on conditions can go many miles. I've had conversations with my cheap Chinese one at roughly 15 miles.
    You'll need to get ham licenses though to use them.
    A ham radio license is free, although sometimes it'll cost $15 or so to take the test. The lowest level, a technician class, is not difficult to obtain, and would be fine for your needs.
    Short of that, gmrs is going to be the next best bet.
    The FRS radios that are cheap and easily available are mediocre even in the best circumstances.
  6. Sep 11, 2019 at 7:30 AM
    682bear
    West GA
    Thanks for the replies... my dad has been a ham operator since the 50's, but doesn't own a handheld unit... maybe I need to explore that option...
    Thanks again... maybe we can figure out something.
    -Bear
    0xDEADBEEF likes this.
