2 weeks no flight 370... wtf?
Discussion in 'Off-Topic Discussion' started by 4WD, Mar 21, 2014.
Thread Status:
Not open for further replies.
  1. Mar 21, 2014 at 9:05 PM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    I said it from the beginning and will say it again, It`s on the ground
    By now Im sure it has a nice fresh paint job.
    There are several monitors on that plane that cant be turned off on the plane.
    Someone knows exactly where it is.
    Read this if you want to know more about the plane.
    From a pilot that works for American Airlines and yes he does fly the 777.
    Just a quick update with what I know about the Malaysia 777 disappearance. The Boeing 777 is the airplane that I fly. It is a great, safe airplane to fly. It has, for the most part, triple redundancy in most of its systems, so if one complete system breaks (not just parts of a system), there are usually 2 more to carry the load. It’s also designed to be easy to employ so 3rd world pilots can successfully fly it. Sometimes, even that doesn’t work…as the Asiana guys in San Fran showed us. A perfectly good airplane on a beautiful, sunny day…and they were able to crash it. It took some doing, but they were able to defeat a bunch of safety systems and get it to where the airplane would not help them and the pilots were too stupid/scared/unskilled/tired to save themselves
    There’s many ways to fly the 777 and there are safety layers and redundancies built into the airplane. It is tough to screw up and the airplane will alert you in many ways (noises, alarms, bells and whistles, plus feed back thru the control yoke and rudder pedals and throttles. In some cases the airplane’s throttles ‘come alive’ if you are going too slow for a sustained period of time) All designed to help. But, it’s also non-intrusive. If you fly the airplane in the parameters it was designed for, you will never know these other things exist. The computers actually ‘help’ you and the designers made it for the way pilots think and react. Very Nice.
    Now to Malaysia. There are so many communication systems on the airplane. 3 VHF radios. 2 SatCom systems. 2 HF radio systems. Plus Transponders and active, ‘real time’ monitoring through CPDLC (Controller to Pilot Data Link Clearance) and ADS B(Air Data Service) through the SatCom systems and ACARS (Aircraft Communications Addressing and Reporting System) thru the VHF, HF and SatCom systems. The air traffic controllers can tell where we are, speed, altitude, etc as well as what our computers and flight guidance system has set into our control panels. Big Brother for sure! However, most of these things can be turned off.
    But, there are a few systems that can’t be turned off and one, as reported by the WSJ, is the engine monitoring systems (not sure what the acronym for that is, but I’m sure there is one….it’s aviation…there has to be an acronym!). The Malaysia airplane, like our 777-200’s, use Rolls Royce Trent Engines (as a piece of trivia….Rolls Royce names their motors after rivers….because they always keep on running!) Rolls Royce leases these motors to us and they monitor them all the time they are running.
    In fact, a few years back, one of our 777’s developed a slow oil leak due to partial equipment failure. It wasn’t serious enough to set off the airplane’s alerting system, but RR was looking at it on their computers. They are in England, they contact our dispatch in Texas, Dispatch sends a message to the crew via SatCom in the North Pacific, telling them that RR wants them to closely monitor oil pressure and temp on the left engine. Also, during the descent, don’t retard the throttle to idle…keep it at or above a certain rpm. Additionally, they wanted the crew to turn on the engine ‘anti ice’ system since it heats some of the engine components.
    The crew did all of that and landed uneventfully, but after landing and during the taxi in, the left engine shut itself down using it’s redundant, computerized operating system that has a logic tree that will not allow it to be shut down if the airplane is in the air…only on the ground. Pretty good tech. Anyway, the point was, that RR monitors those engines 100% of the time they are operating.
    The WSJ reported that RR indicated the engines on the Malaysia 777 were running normally for 4 to 5 hours after the reported disappearance. Malaysia denies this. We shall see.
    Parting shot - If you travel by air, avoid the 3rd world airlines. Their operators and maintenance are substandard. Substandard when traveling by Bus or Boat isn’t so bad when the engines quit. You just stop on the water or by the side of the road. Not so in airplanes.
    My piece of advice….if traveling by air use 1st world airlines. So, that leaves USA, Canada, Australia, New Zealand, most of Europe, Japan and just a few others. Avoid the rest….just my opinion. If you get a real deal on air fare from ‘Air Jabooti’…skip it. Oh, there are a lot of the ‘developing’ countries that use expatriate pilots from the 1st world. Emirates and Air Jordan come to mind and are very safe. As is Cathay Pacific. Air Pakistan and Egypt Air…not so much. Do the research.
    And don't EVER get in an Airbus!!
  2. Mar 21, 2014 at 9:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    She found the pieces of her life?
  3. Mar 21, 2014 at 9:11 PM
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    & theres the guys that would appear to have some real world working knowledge of said aircraft.... Hey its plausible to me its on the ground somewhere.. or in...
  4. Mar 21, 2014 at 9:12 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    only good guess i have is the com system must have somehow all shut down, then ended up landing in the ocean (soft enough as to not destroy the plane) and it sunk and any survivors drowned...
    you would think they would be able to find a commercial jet by now if it was anything else
  5. Mar 21, 2014 at 9:15 PM
    01TacoBuz
    In the woods
    01 Tacoma SR5
    And dont believe anything that the lame stream media is saying about this
  6. Mar 21, 2014 at 9:18 PM
    4WD
    Doug
    2004 DC TRD 4x
    Thats what i'm sayin'...i guess .. Admittingly i don't know shit about current radar /real time GPS tracking/coverage areas, all that shit just amazingly coincedental all the redundecies as mentioned all fail (per say, in relation to tracking/transponders etc)
  7. Mar 21, 2014 at 9:22 PM
    01TacoBuz
    In the woods
    01 Tacoma SR5
    I dont either but an American Airline pilot does, the sad part is if the wrong person finds out who the pilot is that put the truth out there, he may be in danger.
  8. Mar 21, 2014 at 9:23 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    This...they'll come up with some new news and eventually will forget about this "incident".
    complete and obvious cover up for government actions.
  9. Mar 21, 2014 at 9:28 PM
    01TacoBuz
    In the woods
    01 Tacoma SR5
    Until the plane slams into a building and then the medias hero will claim that he did something special. Like save the day . :rolleyes:
    Wait for it.
  10. Mar 21, 2014 at 9:34 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  11. Mar 21, 2014 at 9:39 PM
    worthywads
    Can't the aluminum protects me.
  12. Mar 21, 2014 at 9:55 PM
    worthywads
    Your cut and paste isn't what I'm laughing at.
  13. Mar 21, 2014 at 9:58 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    No ransom demand, and no terrorist groups claiming responsibility. Leads me to think that plane is under water, possibly a great deal of water.
  14. Mar 21, 2014 at 9:59 PM
    01TacoBuz
    In the woods
    01 Tacoma SR5
    Your location tells me and anyone/everyone with half a brain why you are laughing.
    If you dont know what Im talking about, I rest my case. :D
    Have a great weekend. :)
  15. Mar 21, 2014 at 10:02 PM
    #35
    01TacoBuz
    In the woods
    01 Tacoma SR5
    Why would they claim responsibility if their plan is not completely played out yet, most criminals are dumb, this is true, but these guys are not dumb, they stole a big ass jumbo jet.
    If they show their hand now their plan will not be as effective.
  16. Mar 21, 2014 at 10:04 PM
    #36
    4WD
    Doug
    2004 DC TRD 4x
    Wow, thats alot of info bro'.... Are you the one that suggested everyone scan imagery ?? (being serious here)
  17. Mar 21, 2014 at 10:05 PM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    And some of the phrasing and statements in that cut & paste lead me to believe that it was not written by a pilot.
  18. Mar 21, 2014 at 10:06 PM
    #38
    worthywads
    Half a brain. How appropriate. ;)
  19. Mar 21, 2014 at 10:06 PM
    #39
    01TacoBuz
    In the woods
    01 Tacoma SR5
    Im from the Govt and Im here to help. LOL
    I hope you dont believe that. :D
    Been fun, gotta run, Have a good weekend :)
  20. Mar 21, 2014 at 10:07 PM
    #40
    worthywads
    He got it off the internet, of course it's legit. :confused:
Thread Status:
