2 wheeler question?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Roy Matson, Nov 3, 2008.
  1. Nov 3, 2008 at 1:19 AM
    Roy Matson
    Roy Matson [OP] Member
    Daryl
    minnesota
    03 SR5 4x4
    in dash gps and custom subs, 2.5 "coil spacers & 2" blocks, aluminium wheels & 33" Yokohamas
    Im jus wonderin how all you 2 wheel drive taco owners do out in the mud? Do they do ok or u usually get stuck? Cuz i always end up stuck until 4 wheel saves me!!
  2. Nov 3, 2008 at 10:37 AM
    backwoodking
    backwoodking Well-Known Member
    Thousand Oaks/Southern CA
    3.4 V6 Deck Plate and Cut Turn-Down
    Deck Plate, Hitch, Cut Turn-Down Exhaust, Tint, Clear Corners, Shell, Full Size bed in the pickup, Hopefully More Soon
    I do ok in the mud, but when we're out in the sand I get stuck on every other run I take.
  3. Nov 3, 2008 at 4:23 PM
    OFFROADCARWASH
    OFFROADCARWASH Well-Known Member
    Jacktown, Mississippi
    2000 Taco customized
    Custom badged black, 100watt LOUDSPEAKER mounted under toolbox, UWS toolbox, All terrain Tires, K&N Ram Air Intake, HUGE flood lights mounted to Tool Box, Cobra CB radio, Francis Antenna, HELLA Blue Headlights, 12 Pad LEDS in Cab lights, Husky Liners, Tinted Windows at 15%, Thrush Glass Pack (burned Out) with 4inch Tip..Remote Crank and Intry, 2 12" subs, Blacked out head lights and tail lights.
    The mud is pretty easy if you know how to drive offroad...The sand IS HELL. never will I go in sand again.
  4. Nov 3, 2008 at 4:34 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Hell i burried mine all the time with 4x4...... :confused:but i think it is my fault...haha:D
  5. Nov 3, 2008 at 4:37 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Sand is actually not that bad at all in 2 wheel drive unless your trying to climb huge hills or tow something. The trick is to air down, I've driven MANY 4x2 vehicles in the dunes. In fact, when i'm in the dunes i'm usually running in 4x2 in my taco, until i really need it..
  6. Nov 3, 2008 at 5:36 PM
    cclax2145
    cclax2145 Well-Known Member
    Houston
    2002 prerunner SR5 Blacked out
    Deckplate mod, K&N drop in, blacked out tails and emblems, 3 inch toytec spacer/AAL lift, Alpine head unit, Boston acustics speakers, and 10 inch image dynamics sub (in custom seat/box), Alpine EQ, Flowmaster 40 series, and viper alarm system, 33inch bfg MTs, 15inch black steelys
    I got bfg Mud terrains on my prerunner and i do pretty good in mud. I just gotta make sure i got decently fast before and use a little momentum to get through it. As far as sand everytime ive been ive done good, only time i got stuck was on a steep climb up a narrow path but that was when i had bald allterrains. So yea 4x2 is alot harder that 4x4 as far as the ease of muding and so on, but for me it sure is alot of fun!
  7. Nov 3, 2008 at 5:43 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I think it has more to do with the ability of the driver rather than the vehicle, although it helps a lot to have a rear locker too.
  8. Nov 3, 2008 at 5:52 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    went to glamis in my prerunner. Aired down the tires and did my thing. Never been in the mud. Not many places you can go mud boggin in So Cal.
