20/20 Tacoma transmission drain and fill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dennisrose2, Oct 28, 2023.
  1. Oct 28, 2023 at 8:02 PM
    Dennisrose2
    Dennisrose2 [OP] New Member
    So I went to the dealership to get transmission fluid for a draining fill 2020 Tacoma TRD off-road he said I would need 6 quarts when I drained my fluid I only retained 2. 6 quarts ??? Does this mean I was low?? Could not get a straight answer from anyone about how much fluid it takes to do a drain and fill. dealership, videos?? Call the dealership back ask him how much it would take to do a drain and fill on my vehicle he told me 10 quarts?? Can anybody help me out with this question it can't be this difficult
  2. Oct 28, 2023 at 8:18 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    If you're just draining, you should have had roughly....give or take 3qts come out. Refilling you put in 3.5-4qts so its overfilled, then take out the overflow plug on the transmission once it's at the required temperature level to do the check.
    EDIT - I believe if you're dropping the transmission pan, then the refill amount is 10qts or slightly more, I don't remember.
  3. Oct 28, 2023 at 9:35 PM
    Dennisrose2
    Thank you
  4. Oct 29, 2023 at 3:55 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Dropping the trans pan and changing filter only gets you about a quart above what you've drained. You will only get full 10 if you bust out the torque converter and transmission.
    Technique[QUOTED] likes this.
  5. Oct 29, 2023 at 4:03 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    This is incorrect.
    Dropping the pan will only remove about an additional 1/2 to 1/3rd of a quart
  6. Oct 29, 2023 at 4:38 AM
    Two4Runner
    Two4Runner Well-Known Member
    LD
    Shreveport
    2017 DCSB TRD Offroad 4x4
    I've done drain and fill twice and only about 2.75 quarts came out each time. I used a clear marked bucket for drain and put the exact amount back in
    EL DUDE likes this.
  7. Oct 29, 2023 at 7:44 AM
    tiap
    tiap Active Member
    You should check the correct amount with the "overfill bolt method"
    Some claim that the level from the factory was incorrect.
    HondaGM and faawrenchbndr like this.
  8. Oct 29, 2023 at 8:20 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Here is the Toyota doc
    HondaGM likes this.
  9. Oct 29, 2023 at 8:54 AM
    Technique
    Alex
    Utah
    As tiap said, you should really follow the correct procedure for checking the fluid level via the overflow valve. So many of these trucks came with the wrong fluid level from the factory. Plus it only takes a few minutes to do the check with the overflow plug.
  10. Oct 29, 2023 at 9:10 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Either the service writer is trying to up charge you or he incompetent,either way easy to do or find another dealership.
    PTSDTherapy likes this.
  11. Nov 2, 2023 at 11:37 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    When I got my ‘23 I checked all fluids and the trans was 1.2 QTs low from the factory. It’s always good to recheck even after having someone do it.
    2.7 QTs drain from the pan if doing a drain and fill. You add 3 QTs and do the temp check to drain the rest to spec at temperature.
    G8R_Taco likes this.
  12. Mar 11, 2025 at 1:40 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Interesting, I notice that this document as well as the discussion is not mentioning the filter in general... Does this filter perhaps have a really long lifespan compared to older vehicles?
  13. Mar 11, 2025 at 1:44 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    ah nvm, found this video..
    https://www.youtube.com/watch?v=tFMy2CrWSQI
    I remember having fun replacing the filter and gasket on my Ranger's transmission.. biggest PITA was carefully scraping off mating surfaces and then getting the filter gasket to stay in place before I discovered High-Tack Gasket Sealant
    Snobdds and TreeFortRichard like this.
