20" enkei wheels tire size qusetion please help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yosimdisam, May 30, 2011.
  1. May 30, 2011 at 7:36 PM
    yosimdisam
    yosimdisam [OP] Member
    Robert
    Birmingham, AL
    09 reg cab 4x4
    I just bought some 20" enkei wheels from a guy off craigslist, Im not a big fan of the big wheels but I got a good deal on them but the tires are wore out and im going to have to buy a new set. Does anyone know whats the biggest tire I can put on them with out them rubbing? Its a 09 reg cab 4x4 truck. I dont like the big wheel low profile look on a 4x4 truck. Thanks for any help, Robert
  2. May 31, 2011 at 11:25 AM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    Does anyone have any idea?
  3. May 31, 2011 at 11:27 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    not very big i say sell them for more and make some money and buy wheels that to want.
  4. May 31, 2011 at 11:28 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    265/55 20?
  5. May 31, 2011 at 11:38 AM
    JLee
    Jerry
    Bay Area NorCal
    Well that's if it's a 20/8 what is the width of the wheels?
    if you have 20/8's these are about as big as you can go stock without rubbing.
    from the online tire size calculator
  6. May 31, 2011 at 11:49 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    20s with stock height will be some pretty low profile tires, if you dont like low profile tires i suggest flipping them (selling them for more) and get something more your type of wheel.
    but i would think 31s would be the biggest
  7. May 31, 2011 at 11:52 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    A few members on here run 285/60/18's on stock suspension, and the tire isn't tall enough (31.4") to hit the UCA, even with more than 4.5" of backspacing.
    Therefore, you should be able to fit 285/50/20's if you so please.
    Or you could run the aforementioned 265/55/20's if you prefer a taller, but skinnier tire.
    Here's a comparison between the two.
  8. May 31, 2011 at 3:31 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    These are the wheels on the truck. They have a 295/45/20 on it right now and do not rub. It has about 1/4 to 1/2 inch clearance.
  9. May 31, 2011 at 3:41 PM
    JLee
    Jerry
    Bay Area NorCal
    man that's wide you might be stuck with that size tire unless you lift the truck. With a 3" lift you could do 295/55/20's that's about a 33/11.5
  10. May 31, 2011 at 3:42 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    So from the tire size calculator it looks like 275/50 is going to be the biggest I can go with. If I go with the 285/50 and it does rub whats the cheapest way to lift it enough to run the 285s ? Thanks for all the help.
  11. May 31, 2011 at 3:45 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    Yea its a little to wide. The 285s are .77 of a inch taller but .39 of a inch narrower.
  12. May 31, 2011 at 3:48 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    I dont want to put a 3" lift on the truck. Isnt there some way to raise it 1" ?
    what about some 5100 shocks?
    If a 3" lift is the only way im going with the 275s.
    The tires that are on it are slick as a peeled onion, Ive got to get some this week.
  13. May 31, 2011 at 3:57 PM
    JLee
    Jerry
    Bay Area NorCal
    Yeah you can do 5100's at .85 or 1.75 to lift it just a little.
    Also in that picture 295's are on the wheels right?
  14. May 31, 2011 at 4:00 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    Are the 5100s only for the front? I looked on ebay and thats all I see for my year is the front shocks.
  15. May 31, 2011 at 4:06 PM
    KPT
    09 Prerunner
    Only the front ones provide lift
  16. May 31, 2011 at 4:08 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    So for the rear its either add a leaf or a lift block right?
  17. May 31, 2011 at 4:09 PM
    KPT
    09 Prerunner
    Correct
  18. May 31, 2011 at 4:24 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    Ive been looking and I really want the add a leaf b/c when I pull a trailer it really lowers the rear end, but the add a leaf is 1 1/2" or 2" lift. I think thats going to be a little much? what do y'all think? I was kinda thinking about 1" on the rear. I dont ever use this truck off road and it is street driven all the time and average 100 miles a day, so I dont want any more lift than I need. Thanks for the help
  19. May 31, 2011 at 4:27 PM
    KPT
    09 Prerunner
    Do you have the rear leaf tsb? It does both of things you want (less squat when towing, and raises rear 1")
  20. May 31, 2011 at 4:29 PM
    yosimdisam
    Robert
    Birmingham, AL
    09 reg cab 4x4
    How do I tell if I have a rear tsb? I doubt I have it, its a base model 4x4 truck. It has a total of 3 leafs if that helps.
