20 HP / 14 lb-ft torque gain from 91 Octane gas on Tacoma Gas Engine 2.4 i-Force (dyno tested by Sti
Discussion in '4th Gen. Tacomas (2024+)' started by RoelStillen, Dec 13, 2024.
  1. Dec 19, 2024 at 5:39 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    how do i put premium electrons in my iforce maxx? to keep you plebs from catching up to me! ;)
    dleithaus likes this.
  2. Dec 19, 2024 at 7:38 AM
    monomial
    monomial Active Member
    2024 Silver Tacoma 4X4 SR5
    I wonder how linear the added octane is for performance. Would a mid-range fuel satisfy the engines octane requirements for full power or would it be half the values shown. Can too much octane have diminishing returns?
  3. Dec 19, 2024 at 8:16 AM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    The engine is rated on 87, so if you're being entirely fair, you'd be getting more than full power.
    But, to actually answer your question, it depends entirely on a particular setup. Only way to find out is to do dyno runs. You could pay a shop to dyno your truck on tanks of different octane fuels and find out. It'd be a nontrivial expense, though. And mostly for funsies.
  4. Dec 19, 2024 at 9:00 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    man, just ignore them and move on, the same people saying 20hp is insignificant for just filling up the pump will be the same people moaning why it's not "worth it" when you post a dyno sheet showing any increase from an air intake
  5. Dec 19, 2024 at 9:15 AM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    :amen:
    turkeyslayer66 likes this.
  6. Dec 24, 2024 at 8:27 AM
    vettaco
    vettaco Well-Known Member
    Vince
    09 AC PreRunner
    Hard to know; other than spending a bunch of money for dyno testing with different octane ratings you could do some acceleration tests on your own. You should get the largest HP increases during hot weather when forced induction engines are most likely to experience pre-ignition causing the computer pulling timing.
  7. Dec 24, 2024 at 8:45 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    If my math is correct, running 91 octane will give a 4% gain in torque.
    That's a high dollar for something you'll never feel. I've never floored my truck in 5,400 miles.
    2024OffRoad and TurboDA6 like this.
  8. Apr 26, 2025 at 1:14 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I decided to try some higher octane gas this week. So far it seems my motor is quieter and a little smoother through the gears. I’m going to run through this tank and a couple more, before I decide if it’s placebo or not.
    tonymac likes this.
  9. Apr 26, 2025 at 1:41 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Agreed. Whole point of a Turbo is to create boost - or increase pressure. The whole point of premium 91 octane is to maximize that pressure.
    Even my NA 3.5 V-6 gets a little better on 91 too. Just not really enough to justify the cost. Best case it breaks even.
    Kinda reads like "This just in, 4 out of 5 scientists agree oxygen is crucial to life."
    WheelinDev likes this.
  10. Apr 26, 2025 at 5:38 PM
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    I hauled fuel for 10 years. We bought from every single supplier you can think of, who ever was the cheapest for each load. BP/Arco, ExxonMobil, Shell, Conoco, Tesoro, Kinder Morgan, Chevron, the list goes on...Believe it or not all the Diesel came out of one load head (hose) and all the gasoline came out of a different load head. The only difference was the additive pack that certain suppliers used. One time after I got done loading, one of the operators came out and said "hey don't leave, your load didn’t get any additives, the pump is down." After I got my paperwork he brought me the "additive". The container was about the size of a 2-stroke mixed gas container. You know, the one for your weeedeater that you mix with 1or 2 gallons of gas. This container was for 11,800 gallons of gas...Ever since then, Chevron with Techron commercials always cracked me up.
    I agree with different octanes making a difference. But Chevron with Tchron or Exxon with Synergy is all BS...
    dleithaus[QUOTED] and tonymac like this.
  11. Apr 26, 2025 at 8:47 PM
    Hadelson
    Hadelson Active Member
    Hugo
    24 Taco Trail Hunter
    Well...................................I have the new CAI for my trail-hunter. 1st hurtle is the fit. Tried to install twice and no joy. Working with Stillen on this issue and will try again tomorrow remaining positive :). Will report back
  12. Apr 26, 2025 at 8:57 PM
    TACO-TY
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    Does the TH have something under the hood that the rest of the trims don't?
  13. Apr 27, 2025 at 6:47 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    I’ve owned a variety of epic turbos, and this one is a proper truck motor that never breaks a sweat. My simple rule of thumb is run premium and tight oil change intervals. Happy turbo, happy life.
    I’m actually interested in seeing how much power other people wring out of these, b/c if they can reliably handle the abuse (er…extra tuning), then it bodes well on longevity for the rest of us.
    gmtech and OpeCity like this.
  14. Apr 27, 2025 at 6:51 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    If you’re deleting PCV valves, I sure hope you’re running a vacuum pump or other source of suction. crankcase ventilation is really important.
  15. Apr 27, 2025 at 7:53 AM
    #35
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    I’ve been running 93 octane since first time refill up just because I’m used to running this octane on my other car. I don’t know if it feels better or not since I’m still in the break in period.
  16. Apr 27, 2025 at 8:36 AM
    #36
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Premium leaded gas had a whopping 0.16 ounces of tetra ethyl lead added per gallon back in the day BEFORE it was reduced drastically to a mere fraction of that amount [0.03 oz per gallon]. A little bit goes a long way with certain chemicals.
    All octane does is slow the burn rate and allow more advance to occur without damaging knock. More advance=more HP, when you go to forced induction, it can have pretty significant results in a modern engine with sophisticated knock sensors.
  17. Apr 27, 2025 at 9:35 AM
    #37
    TACO-TY
    Tyler
    Eastern WA
    '24 SR6-MT DCSB
    1st tank I put in prem. 2nd I put in reg...I don't drive it like a racecar so I won't notice much power difference, especially with the MT. The MPGs were a bit better with premium. My 3rd gen had a premium tune so I'm used to the expense... For piece of mind, I'll be using premium for now on.
  18. Apr 27, 2025 at 10:35 AM
    #38
    Hadelson
    Hugo
    A snorkel. The issue is an electrical connector (Can't be moved) and the passenger side Hood Pad mount.
  19. Apr 27, 2025 at 10:57 AM
    #39
    roalddahl
    roalddahl Well-Known Member
    Don't the detonation sensor and ECU take care of pre-ignition and knock in modern vehicles?
  20. Apr 27, 2025 at 11:02 AM
    #40
    OpeCity
    Long Beach, CA
    Knock sensors sense knock when it’s happening, while higher octane fuels could prevent it before that point.
    I’d get a lot of knock in my old 99 and my Hyundai. Just for a second and mostly at low speeds and high cylinder pressures. The engines did adjust, but I always wished it didn’t happen at all for the sake of longevity
