20 inch wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twk62390, Sep 25, 2010.
  1. Sep 25, 2010 at 9:05 AM
    twk62390
    twk62390 [OP] Well-Known Member
    I've only had the truck a few weeks and have been researching for a week and think I understand this but I would like to check before I make a very costly mistake because I am new to the truck scene. I am wanting to run 20" wheels with 285/55/r20 or 285/60/r20 tires and a 3 inch lift (only 20s because it is a prerunner and I plan on doing very minimal offroading). After all the research I have done I realize that the most common is a 4.5" backspace/-12mm offset. I have seen a few trucks on here with the 5.71" backspace/18mm offset though and this is where I feel i may be slightly confused. To get the -12mm offset I will have to get the 20x10 wheels, or to get the 18mm offset I can get the 20x9s. My question is what wheels will rub the least? I know both will rub, but I do not want to rub so much that my cab mounts have to be cut. Based on all of my searching I feel that the 20x10s will be fine with the -12mm off set. Am I correct?
  2. Sep 25, 2010 at 9:29 AM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    Try 17's with 285/70/17 bfg's, these work great with no rubbing :D
  3. Sep 25, 2010 at 9:36 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  4. Sep 25, 2010 at 9:39 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    wat
  5. Sep 25, 2010 at 9:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think the 20x10 would be too wide, but I dont know much about wheels. Someone else should chime in soon...
  6. Sep 25, 2010 at 9:50 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    i think he means he wants to run either a 285/55/20 or 285/60/20 tire
  7. Sep 26, 2010 at 9:13 AM
    twk62390
    yea....thats how I should have said that.
    I also feel like 20x10 would be too wide, but i have found quite a few on here running 20s. From previous knowledge I have found it is hard to find 20s in anything smaller than than a 20x9 so thats why I feel like someone on here has to be running 20x10. I have pmed several people with 20s but no one has replied so I started a thread.
    Is anyone running 18x10s, maybe this would answer my question as well.
  8. Sep 26, 2010 at 10:29 AM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    20x8.5 would be optimum for the truck, but 20x9 would work as well
  9. Sep 26, 2010 at 6:35 PM
    twk62390
    thanks. thats what I kinda figured. Ive been looking at either the fuel octane wheels or xd monsters. Ive emailed one place to find out if either of those were available in the correct width and offset and i was told only 4.5 backspace is available in 20x10. may they be available in the smaller with and 4.5 backspace at other stores?
  10. Sep 26, 2010 at 6:50 PM
    mardoqueo galindo
    mardoqueo galindo Well-Known Member
    marcos
    socal
    08 preruner
    toyota 20" wheels,borla double tip exaust,running boards,K&N air filter.
    im using the OM 275-50-20 from tacoma TSS on my TRD SPORT double cab short bed 2008 no problem.
