20" lift???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Jul 18, 2019.
  1. Jul 18, 2019 at 9:19 AM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    No it can't.
    But I've had OME 888 coils on my 5100s for 5 months now and they are sagging to about 2" lift at most. No weight in front. I know lots of people have been having the same issue. So I emailed ARB directly and they are having me send them pictures and measurements.
    Will update through out process.
  2. Jul 18, 2019 at 9:25 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    These posts. All coils lose some of their initial height. I had 887s, measured just at 2.5" of lift after installing, 3 months later 2". A year later, still 2". All trucks are going to get different lifts as well, albeit a minute difference, a difference all the same.
    Put some top plate spacers on, a 1/4" will bring it to 2.5" and the spacers wont change over time.
  3. Jul 18, 2019 at 9:26 AM
    Dr. Emmett Brown
    These comments...
    I've got 1/4" spacers and I'm below 2" lift.
    Any other thoughts?
    Edit. Leaning towards saying fuck it and grabbing 2.0 fox coilovers
    Skydvrr likes this.
  4. Jul 18, 2019 at 9:26 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Great Scott!! Who sells a 20" lift? Asking for a friend...
  5. Jul 18, 2019 at 9:29 AM
    elduder
    Van WA
    5100s or nitrochargers?
  6. Jul 18, 2019 at 9:30 AM
    Dr. Emmett Brown
    5100s. Tried setting them up a notch but because the coils are so much longer than stock coils without any load on them, it's a pain the in the ass to try and preload them and reinstall
  7. Jul 18, 2019 at 9:30 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Why do we gotta compensate? Why can't they make the coil a 1/4" taller?
    Dr. Emmett Brown[OP] likes this.
  8. Jul 18, 2019 at 9:30 AM
    Dr. Emmett Brown
    Thinking about double stacking two bullet proof 10" lifts.
    geekhouse23[QUOTED] and Mully like this.
  9. Jul 18, 2019 at 9:31 AM
    elduder
    Van WA
    Im going to ask, just because I do want to help, if I can. Is the perch installed correctly? Ive seen them on upside down and the lowers the total lift.
  10. Jul 18, 2019 at 9:33 AM
    Dr. Emmett Brown
    Definitely install the perch with he correct side facing up.
    The thing is, I initially started out with almost 3" lift in the front.
    elduder[QUOTED] likes this.
  11. Jul 18, 2019 at 9:34 AM
    tcjacado
    tcjacado Well-Known Member
    That's a bad idea. The compression of that spring will RIP the perch off of that 5100.
  12. Jul 18, 2019 at 9:34 AM
    elduder
    Van WA
    Bummer, guess the only option now is Kings, Lol.
    Hopefully ARB helps you out. Thats quite the variance, especially with the spacer.
  13. Jul 18, 2019 at 9:35 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Click-bait title got me excited; thought it was Friday already. :smash:
    geekhouse23 and Skydvrr like this.
  14. Jul 18, 2019 at 9:35 AM
    Dr. Emmett Brown
    Don't guys put 886s on these shocks? Those are heavier springs which would created more pressure under normal circumstances right?
  15. Jul 18, 2019 at 9:36 AM
    Dr. Emmett Brown
    I wouldn't be pursuing help from ARB if I hadn't put the 1/4" spacers on because like you said, coils will sag. I just didn't expect them to sag this much.
  16. Jul 18, 2019 at 9:36 AM
    elduder
    Van WA
    The 886s are actually still around stock lb/in, the valving on the shocks make them rough though. But they would lift it from where you're at.
  17. Jul 18, 2019 at 9:37 AM
    tcjacado
    The ome springs are not supposed to be compressed on anything but the lowest setting 0 on 5100's. If you do, it is not safe. Js
  18. Jul 18, 2019 at 9:37 AM
    Dr. Emmett Brown
    Hahaha I apologize. However, I did address the title in the first sentence :D
  19. Jul 18, 2019 at 9:37 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I want a 20" lift on my running shoes.....
    geekhouse23 likes this.
  20. Jul 18, 2019 at 9:37 AM
    elduder
    Van WA
    Understood, my comment was prior to know that as well. Makes sense now.
