200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Oct 1, 2013 at 6:59 PM
    #201
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Turned 196k today, I wish I could say the same thing about you 200k guys about no troubles, but ive rebuilt the tranny, replaced lbj's and tie rods,steering rack bushings, my rear differential wont lock, replaced battery and battery cables, carrier bearing, going in Monday for alignment, refurbish my rotors, look at the rack and pinion, and I am also going to need tires here soon :bananadead: If only I could have spent that good sum of cash on mods legitimate mods :rolleyes:
  2. Oct 2, 2013 at 12:51 PM
    #202
    Augie95toy
    Augie95toy Augies Adventures
    Andrew
    Old Town VA
    1st Gen Tacoma for play
    Bumpers, skids, OME suspension,
  3. Oct 2, 2013 at 1:24 PM
    #203
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    atta boy!
    love seeing dirty tacomas
    just hit 217K on Monday!!!
  4. Oct 4, 2013 at 10:17 AM
    #204
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Can a newbie join the club?
    '96, V6, 213,000 miles. No problems.
  5. Oct 4, 2013 at 1:11 PM
    #205
    Spandau
    Spandau New Member
    Cinci, O.
    96 Tacoma 2WD
    96 2WD Tacoma single cab, 179xxx, replaced starter, alternator belt, clutch master & slave cylinders, and both front upper & lower ball joints. Hoping to get another 100k out of it....
  6. Oct 5, 2013 at 1:44 AM
    #206
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    95.5, 3.4, stick, 216k
    I've only owned it for about a year: other than a new timing belt, new O2 sensor, and a failed clutch replacement; I don't know of anything major that the previous owner did
    I haven't done anything major except get the clutch replaced (properly)
    I do need to do need to replace the front brakes, including rotors (probably), soon
  7. Oct 5, 2013 at 8:51 AM
    #207
    therexinator
    therexinator Oregon Member / IG: reeeeeeeeeeeeeeeex
    Rex
    Oregon
    2018 DCLB OR
    I promised my fiancé I wouldn't modify this truck... I lied.
    1998 3.4L Automatic - 247k
    Bought it at 170k, timing belt and water pump, brake pads, starter, rack bushings, and new tires, thats it for serious stuff. Then a bunch of other stuff that didn't need fixed but a guy has to keep occupied somehow.
  8. Oct 9, 2013 at 7:26 PM
    #208
    hutch84
    hutch84 Whitewater Dreamin'
    Jeremy
    Blacksburg, VA
    2000 Tacoma SR5 & 2017 Tacoma SR5 (stock)
    5100 w/881's @ 0", OME Dakars, OME greaseable shackles, blinker mod......321K and still kickin'
    236,100mi - v6
    My dad bought it with about 30K and I bought it with about 130k.
    Runs great, need a new valve gasket but it has the original clutch
    Just bought Dakar springs and working on Bilsteins and 883!!
  9. Oct 9, 2013 at 7:42 PM
    #209
    crazed
    crazed Active Member
    Carl
    Missouri
    03 Tacoma DC, SR5, TRD
    235,000 here. 3rd owner, runs great. Routine maintenance always done and have the records to prove it. Replaced the rear-end was the only problem. I am a long time Ex-Toyota mechanic and have always had some sort of Toyota for the past 30 years. They build the best.
  10. Dec 1, 2013 at 9:12 AM
    #210
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    274k. I've replaced the starter and alternator this year - both appeared to be OEM. When I bought it last year at 268k, I did all ball joints / tie rod ends and steering rack bushings (rack bushings had play, as did one of the inner tie rod ends).
  11. Dec 7, 2013 at 2:11 PM
    #211
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    Just turned 390K on my 1998. It's been in the family since new. Has the original engine, trans and even the original clutch. Only minor repairs up to this point and still running like a top.
  12. Dec 7, 2013 at 2:24 PM
    #212
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    The "Chic Magnet".
  13. Dec 7, 2013 at 10:21 PM
    #213
    MoMatt
    MoMatt Member
    98 4x4 Ltd / TRD Stock
    Grey wire mod
    Meh. Let us know when you hit 400k.
    :D
  14. Dec 8, 2013 at 1:04 AM
    #214
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    226k on the beater 2rz truck and 10 miles on my freshly built 3rz 4x4 truck.. now only if I can get it running FUUUUCKKK!
  15. Dec 8, 2013 at 3:31 PM
    #215
    Bren
    Bren Well-Known Member
    CT
    01 Tacoma SR5 V6
    01 3.4 with 206k. Runs like new.
  16. Dec 9, 2013 at 3:40 PM
    #216
    Polonia
    Polonia Member
    tom
    niagara falls
    tacoma TRD
    borla exhaust
    2005 double cab 6speed at 163000.... Just getting broken in...lol
  17. Dec 9, 2013 at 3:47 PM
    #217
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Im 3000 miles shy...
  18. Feb 11, 2014 at 3:53 AM
    #218
    domlir95
    domlir95 Member
    Alaska
    95 Tacoma DX 4x4 Ext Cab
    3" suspension lift, 33" tires
    hey. Bought the truck at 203K. Had to redo the VCG but no major issues. Also did the plugs and wires too. I have a question though. I'm going to be taking it on a rather long road trip. I'm not sure of its full maintenance past, but what should I look into replacing or cleaning for said road trip? I'd like to do the timing belt and pump and all just for peace of mind(not sure when it was done last). Also, clean all the components I can i.e MAF, IAC, TB all that good stuff. Any suggestions on what should take precedence, and what things to avoid when doing said jobs? Any info is helpful. Thank you Tacoma world. I love my Tacoma
  19. Feb 11, 2014 at 8:20 AM
    #219
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    99 2.7 with 205K. Original clutch, rack and pinion, ball joints, u joints, rear brakes, water pump, alternator,,,ect.
  20. Feb 12, 2014 at 5:56 AM
    #220
    tquinn
    tquinn Member
    Tim
    NC
    Tacoma SR5 TRD 4WD
    2001 Tacoma 4WD extcab TRD SR5 2.7l 4 banger 227,000 miles with no problems. Replaced 1 set of belts, and tensioner pully on AC (bad bearing) 1 set of front brake pads and 1 front brake rotor. The only problem I have is a sticky throttle cable that I need to fix, I've seen a few other post with the same problem, throttle has a bad spot on the top (accelerator not pressed) and you have to press it pretty hard at times to get it free, otherwise it has been a joy to own and drive for the last 13 years.
