200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Jul 27, 2017 at 7:43 AM
    #441
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Curious
    Your 2.7L needed a full engine rebuild ?
  2. Jul 27, 2017 at 7:48 AM
    #442
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    No. Bottom end looked fine. I pulled the motor to replace the timing chain and water pump, figured I had it pulled might as well rebuild it. It is my dd/farm truck, but I have other vehicles so I wasn't in any hurry to finish it. It does run much better now than it did. I am at least the second owner of this truck, the valves were never checked until I did it the first time at 150k miles. Cylinder head was cracked between 2 and 3 I think on the exhaust side (machine shop tested). Again, since the cylinder head was cracked I tore the block down and had the deck checked, crankshaft polished and replaced the pistons/rings/wrist pins and all the bearings (twice... long story with oil pump shattering in the first start up).
    Best thing I installed while doing the rebuild was a better oil pressure and temp gauge..
    Dalandser and PROseur[QUOTED] like this.
  3. Jul 27, 2017 at 7:55 AM
    #443
    jarebear74
    jarebear74 Bar down or it doesn’t count
    Colorado Springs, CO
    2010 OR DCSB
    Not in the 1st gen. But a 94' isn't far off. 265k miles. Ridin smooth.image1.jpg
    Dalandser, GA-3RZFE and 2002Tacoma4x4 like this.
  4. Jul 27, 2017 at 8:07 AM
    #444
    PROseur
    Pussy
    Was there sign of leaked coolant or oil burn ?
  5. Jul 27, 2017 at 8:22 AM
    #445
    GA-3RZFE
    cylinder misfire #3 (severe). Exhaust gas in coolant system.
  6. Jul 27, 2017 at 8:23 AM
    #446
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    213,000 miles. No malfunctions. Doesn't burn or leak a drop of any fluids.
  7. Jul 27, 2017 at 3:57 PM
    #447
    SteveinPa
    SteveinPa New Member
    2004 Extended Cab 323,000. Bought it new in July 2004 with 23 miles on it.
    Still on the original clutch believe it or not!
  8. Jul 27, 2017 at 5:44 PM
    #448
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    :worthless::worthless::worthless::worthless:
    PROseur likes this.
  9. Jul 27, 2017 at 5:51 PM
    #449
    SteveinPa
    Dark now, will get tomorrow!
    2002Tacoma4x4[QUOTED] likes this.
  10. Jul 27, 2017 at 7:46 PM
    #450
    01GreenTacoma
    01GreenTacoma Well-Known Member
    236,000 on this gem of mine. Got it in august 03 with 26k on odometer.
    2002Tacoma4x4 likes this.
  11. Jul 27, 2017 at 11:29 PM
    #451
    otis24
    Mark
    California
    Oh right! From last weekend
  12. Jul 28, 2017 at 6:15 AM
    #452
    jrmyrnsm
    jrmyrnsm Member
    Jeremy
    Middle GA
    2001 Tacoma Double Cab
    Sitting at 241k over here. Doesn't leak any fluids and still gets 20mpg on the highway. Only minor maintenance and I need to replace my cat...
  13. Jul 28, 2017 at 6:27 AM
    #453
    otis24
    Mark
    California
    I think this is my favorite 1st gen color.
  14. Jul 28, 2017 at 7:35 AM
    #454
    VDubman55
    VDubman55 New Member
    Mark
    1998 2wd Tacoma extra cab
    None
    I'm new here. Just stumbled onto the site. I'm on my 4th Toyota 2wd('79-285k,'81-297k,'88-308k,'98)My '98 now has 374,xxx still runs great. Original everything except new clutch pack about 25,000 miles ago. It is going to need the intermediate steering shaft replaced soon, getting pretty loose!
    Dalandser and otis24 like this.
  15. Jul 28, 2017 at 8:16 AM
    #455
    otis24
    Mark
    California
    A lot of people tack Weld that shaft.
    https://youtu.be/6O01xIDnuk8
    Dalandser likes this.
  16. Jul 28, 2017 at 8:50 AM
    #456
    VDubman55
    Mark
    None
    I have seen that video, but the u-joint on the shaft is also bad.
  17. Jul 29, 2017 at 6:27 PM
    #457
    cazinpa
    cazinpa Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    2.7L is amazing!
    PROseur and Dalandser like this.
  18. Jul 29, 2017 at 7:58 PM
    #458
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    1/8" roll pin from Home Depot works too if you don't have access to a welder.
  19. Jul 29, 2017 at 8:52 PM
    #459
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    Will be here in 12 months God willing
  20. Jul 29, 2017 at 8:57 PM
    #460
    Solid Seung
    Solid Seung GWOT Infidel
    New California Republic
    2013 SC V6 DCSB TRD OR 4x4
    TRD Supercharger aFe Stage-2 Si Pro DRY S CAI JBA Cat4ward Shorty Headers TRD Performance Exhaust PLX Wideband Air/Fuel Sensor Module Speedhut Boost & Wideband Air/Fuel Ratio Gauges CravenSpeed Flexpod ScanGauge SGIIFFP Computer Uni Filter Mod Mobil 1 Synthetic Oil Pelfreybilt Off-Road: Aluminum Front Plate Bumper, Rigid DOT/SAE Fog Lights, Pelfreybilt Hawse Fairlead & Flipster Winch License Plate Bracket, Aluminum IFS Skid Plate, Steel Standard Rear Bumper, Smittybilt 3/4" Black D-Rings w/Daystar Isolators & Washers KB Voodoo Tailgate Cap System King Shocks 2.5 Front Remote Reservoir Coilovers SPC Light Racing UCAs King Shocks 2.5 Rear Remote Reservoir Shocks OME Dakar EL095R Leaf Spring Set Wheelers Off-Road Front SuperBumps, Rear U-Bolt Flip Kit with SuperBumps Crown Performance Red SS Brake Line Kit Body Mount Chop Tandem Off-road 612 Bravo 17x8.5” Wheels BFG T/A KO2 285/70R17 Tires Redline Tuning QuickLIFT ELITE Hood Struts Redline Tuning Tailgate EZDOWN TRD Battery Hold Down Duralast Platinum Battery 24F-AGM OEM Black Grille Bezel TRD Pro TOYOTA Grille TRD Pro Black Headlights Sylvania Silverstar zXe H4 Lamps Rain-X Silicone AdvantEdge Wiper Blades OEM Running Boards OEM Tacoma Bed Mat AJT Design Climate Control Knobs WeatherTech Floor Liners Covercraft Carhartt Precision Fit Custom Seat Covers Emergency Assistance Kit First Aid Kit Salex Organizers Center Console & Glovebox OCD Anker 36W Dual USB Car Charger PowerDrive+ 2 Type S Drive Dash Camera Garmin nüvi 255W 4.3" GPS Navigator Steadfast Auto 8" Antenna Pioneer AVH-X3500BHS 2-DIN Multimedia DVD Receiver 6.1" WVGA iPod nano 8G (6th Gen) JL Audio XD700 Watt/5 Channel Amplifier JL Audio C2-650X & C2-650 6.5" speakers JL Audio 10W1v2-4 10" subwoofers (x2) in a JL Audio Stealthbox
    Good to hear these testimonials about 200,000 miles. Solid proof the Tacomas are still running strong. I plan to keep mine forever and hope I get to 200,000 miles with no major issues like these proud owners.
