200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Jan 12, 2018 at 11:07 AM
    #521
    Cbtacoma
    Cbtacoma Active Member
    96 Tacoma sas & 02 Tacoma doublecab & 23 tacoma dclb
    Hit 250k a couple weeks ago
    3_TACOS_NEVER_ENOUGH and lsaami like this.
  2. Jan 12, 2018 at 3:54 PM
    #522
    3_TACOS_NEVER_ENOUGH Well-Known Member
    Various Locations: TX, CA, NC, AL, MS, and FL
    I love this thread. I will post the 03 asap. :)
  3. Jan 12, 2018 at 5:25 PM
    #523
    Indyteecee
    Indyteecee bad at building Toyotas, good at breaking stuff
    Wyatt
    Utah
    04 Tacoma Double Cab TRD
  4. Jan 12, 2018 at 9:32 PM
    #524
    Jp Sturm
    Jp Sturm Well-Known Member
    Jp
    Horseshoe Bend Idaho
    95 Sx 5 speed
    Rust! My sworn enemy! My truck is beginning to rust in the same place as yours did.. Drivers side rear :(
    lsaami[QUOTED] likes this.
  5. Jan 14, 2018 at 6:08 PM
    #525
    CO06TaCO
    CO06TaCO Well-Known Member
    01 Tacoma DCSB TRD OR Supercharged
    288K here on my 1st gen DCSB, not sure how long supercharged, but definitely over 150K miles. Runs amazing. Did have to do a lot of front end work recently, I assume from previous owners off roading and the heavy front bumper! [​IMG]
  6. Jan 14, 2018 at 6:11 PM
    #526
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    Mine is at 228000 and 10000 miles ago I put a turbo on it. It running strong !! And I’m the original owner. I’ve replaced front end ball joints etc.... and regular maintenance.
  7. Jan 22, 2018 at 10:45 AM
    #527
    taco lifter
    taco lifter Well-Known Member
    James
    2002 Tacoma 3.4 crew TRD off road
    3" Trailgear lift, rack on camper shell, deck plate mod, led
    How much did the turbo setup cost all together, do you still have acc., and did you find a huge hp increase?
  8. Jan 22, 2018 at 10:54 AM
    #528
    Jstand
    Irving,Tx
    It cost roughly $2500 and if you mean A/C yes and I will be putting fuel management in soon which will get everything working well. Most likely around 100 increase at 10psi
  9. Jan 24, 2018 at 2:13 PM
    #529
    Flaps
    Flaps Well-Known Member
    Ted
    2004 tacoma 4x4 v6 TRD DCSB
    Your right, Great truck, pretty sure I'll never buy another car. I've had mine since 2006 2004 sr5 v6 4 door 114k Been great no problems except for fuel air sensors. change the oil & filter very 3k. ( oils cheap )
    I've haven't changed fuel filter yet. Any thoughts when it should get changed.
  10. Jan 24, 2018 at 2:53 PM
    #530
    Jstand
    Irving,Tx
    I did mine late at 225000 miles or so but I think its 150000 miles.
  11. Jan 24, 2018 at 4:07 PM
    #531
    quag600
    quag600 Active Member
    03 Xtra cab Mystic Gold
    DEBADGED
    Just Made It!
  12. Jan 24, 2018 at 5:12 PM
    #532
    Flaps
    Ted
    thanks!
  13. Jan 26, 2018 at 10:31 PM
    #533
    DirtyAnimal1
    DirtyAnimal1 Active Member
    G
    2001 Tacoma 4
    After market headlights , seat covers ,
    198,000 miles on this 2001 , I had a 2000 that had 225 ,000 It got stolen , The one before these 2 was a 98 that I put 300,000 on it before I sold it for $4k , 1st gen you can’t go wrong , 4cyl or 6 cyl I like the 6 cyl alot better though….
    TacoYankee and Taco Addiction like this.
  14. Jan 26, 2018 at 10:37 PM
    #534
    phillipthetaco
    phillipthetaco Well-Known Member
    Marcus
    Mesa,AZ
    2007 Tacoma Prerunner Barcelona Red
    Wheels and Tires: (5) 35/12.50/17 Toyo R/T tires (5) 17” x 8.5” Matte Black Method NV wheels Black extra thread (ET) spline lug nuts Front Suspension: Total Chaos 3.5” long travel kit Fox 8” x 2.5” coilovers with remote reservoirs Wheelers Super Bumps Limit straps and clevis mounts Total Chaos shock tower gussets Total Chaos cam-tab gussets Maxtrac 4 inch lift spindle Larger Lexus rotors, calipers and brake pads Stainless steel extended brake lines Rear Suspension: DMZ Fabrication Spring Under Kit Fox 16” x 2.5” smooth body shocks with remote reservoirs Fox 4” x 2.0” hydraulic bump stops (shortened to 3”) Custom low profile bolt in bed cage (1.5” DOM tubing) Boxed frame from fuel tank back Custom tube rear cross-member (1.5” DOM tubing) Custom bump stop mounts and strike pads Stainless steel extended brake lines Performance: AFE cold air intake w/reusable filter Nitro 4.88 Gears w/heady duty seals Custom driveshaft with grease-able slip-yolk Odyssey Extreme battery Armor: Custom front tube front bumper (1.5” DOM tubing) w/custom skid plates and valance Custom rear tube bumper w/license plate mount and led light Exterior Accessories/Body: SDHQ “y-strap” for spare tire mounting Harbor Freight 1.5 ton floor jack w/quick release mount Fiberwerx fiberglass front fenders Fiberwerx fiberglass “TT” style bedsides Custom window tint and tint visor Retrofit style Headlights LED tail lights Custom black mesh grill Viper alarm Rigid Industries 30 inch amber LED Rigid Industries 20 inch white LED Rigid Industries D2 Blue rear chase lights X2 Interior: Pioneer touch screen head unit Kenwood mono amplifier Rockford Fosgate 12" P3 subwoofer Infinity Kappa door speakers (4) Weathertech front floor mats LED interior dome lights
  15. Jan 27, 2018 at 3:53 AM
    #535
    Flaps
    Ted
    What mileage do recommend changing spark plug and what kind.
  16. Jan 27, 2018 at 9:57 AM
    #536
    Klierslc
    Klierslc Well-Known Member
    Dan
    Virginia Beach
    1998 Tacoma 4x4 e-locker
    305,000 on my 98. The only thing on this truck that shows it's age is the lack of padding in the driver's seat!
  17. Jan 27, 2018 at 10:10 AM
    #537
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    240k here. Only thing I've had to replace outside of normal services or things I broke offroad was the radiator around 215k because it got a crack
  18. Jan 30, 2018 at 9:08 PM
    #538
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    Just changed my spark plugs at 231,000 miles. Turns out it was the original set. They were a little toasty.
    I bought the truck at 145,000 and assumed the previous owner did the last set at 100,000. Guess not. IMG_4839 2.jpg
    ¯\_(ツ)_/¯
    FLBAdrian and socarboy99 like this.
  19. Jan 30, 2018 at 9:11 PM
    #539
    roger2chris
    roger2chris Well-Known Member
    Roger
    Pineville NC
    2018 Toyota Tacoma SR5 4x4 MGM DCSB
    WOW that crazy
  20. Jan 31, 2018 at 2:21 PM
    #540
    DirtyPurpleTaco
    DirtyPurpleTaco New Member
    G
    '99 Purple Tacoma
    I have 311 on mine and shes runnin like a top
    Jstand likes this.
