200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Feb 2, 2018 at 8:54 AM
    #541
    sd_N
    sd_N Well-Known Member
    Ozark Mountains
    03 Tacoma Double Cab SR5 TRD 4x4
    Starting new...
    My 98 has over 500 thousand and my 99 has almost 250000. :)
  2. Feb 5, 2018 at 2:25 AM
    #542
    socarboy99
    socarboy99 Pluggin' along by going from A to B to C to D...
    Charleston, SC
    1999 Tacoma Regular Cab 2WD
    TLC (Toyota Loving Care), Kenwood Head Unit with bluetooth
    My lowly 5-lug RWD which I picked up from a local Craigslist seller for $2000 in June 2016 had just turned 250,000 miles. In the 20 months I've had this vehicle, I've put another $2500 in repairs and upgrades including just rebuilding the front suspension and complete brake system. I may of had a wee bit of buyer's remorse a few minutes after taking possession then, but since for a vehicle with now 267000 miles, it runs like gem.
    sd_N likes this.
  3. Feb 5, 2018 at 2:27 AM
    #543
    tacama321
    tacama321 Active Member
    Mondo
    Amarillo, TX
    1997 Toyota Ext.Tacoma 4x4 3.4L
    268,000. Got it 3 months ago. Shocks, Struts, Brakes, Fluids, Injectors, Sensors: coolant temp. MAF, TPS, very impressed with vehicle. Believe mileage not an issue, Maintenance Most Important and a Toyota Product!!!
    Coolidge and socarboy99 like this.
  4. Feb 5, 2018 at 7:30 PM
    #544
    ThatRedYota
    ThatRedYota Well-Known Member
    Nikola
    2003 Red Prerunner TRD Offroad
    Fox 2.5 IFP Coilovers, BTF uniball UCA's 295/75/r16 Toyo AT2s, front tube bumper (custom), rear tube bumper (custom), radiator guard, Assault light bar, Stereo, 3D printed Offroad switch panel/ mount
  5. Feb 8, 2018 at 6:03 PM
    #545
    04Burk
    04Burk Well-Known Member
    Glen
    Hinesville, GA
    04 4x4 V6 Xcab 217k miles
    04 Tacoma 4x4 3.4 front end suspension replaced. Replacing clutch, timing belt, and rotors next month1518141777746623762992.jpg
  6. Feb 9, 2018 at 2:39 AM
    #546
    yayayayayaya
    yayayayayaya Active Member
    Patrick
    Alaska
    1999 V6 Tacoma
    Keeping it tame
    306K and everything seems to need to be replaced, especially chassis issues, :((((
    04Burk likes this.
  7. Feb 9, 2018 at 2:39 AM
    #547
    yayayayayaya
    Patrick
    Alaska
    1999 V6 Tacoma
    Keeping it tame
    I mostly cry about it on forums before I actually get to it :))
  8. Feb 9, 2018 at 6:02 AM
    #548
    Cullen2x4
    Cullen2x4 Member
    Cullen
    1998 Toyota Tacoma Pre Runner
    256,000 still runs like it did when i got it just had to replace struts the other day only major part i have had to replace so far! love the truck I would highly recommend
  9. Feb 9, 2018 at 6:05 AM
    #549
    Cullen2x4
    Cullen2x4 Member
    Cullen
    I posted a forum ab this and got a good bit of answers go take a look should be able to help you out :thumbsup:
  10. Feb 13, 2018 at 3:59 PM
    #550
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    at 207k. Ive dumped a ton into maintenance, just seeing if there's any other preventative things people would do that im missing, for another couple years of worry free driving.
    new steering rack and poly bushings and fluid and hardware
    new suspension bushings
    ball joints
    tie rods
    new denso radiator and fluid
    transmission cooler added
    fuel filter
    oil change, diff and t case fluids were changed 3 months ago
    rear brakes (fronts are fine)
    plugs and wires
    all 3 belts
    water pump
    anything else I should do?
    Steven G and 1997tacomav6 like this.
  11. Feb 13, 2018 at 10:53 PM
    #551
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    262,000 miles, and still going.
    No real issues, just routine maintenance items.
    Jstand and 04Burk like this.
  12. Feb 14, 2018 at 1:10 PM
    #552
    Joshs95taco
    Joshs95taco New Member
    1995 2.7l 4wd
    95.5 here 280k miles
    socarboy99 likes this.
  13. Feb 17, 2018 at 5:05 PM
    #553
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Sway bar end links for sure. Replaced mine and certainly noticed the difference. Cheap and not too difficult.
  14. Feb 17, 2018 at 5:14 PM
    #554
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rofl: ripping off that piece of crap was the 2nd thing I did when I got the truck.
    I appreciate the suggestion tho!! :thumbsup:
  15. Feb 18, 2018 at 5:47 AM
    #555
    brianhartjr
    brianhartjr Active Member
    Brian
    1996 4x4 lifted Tacoma
    3" lift
    I’ve got 237,000 on mine, running great!
  16. Feb 18, 2018 at 5:57 AM
    #556
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    01 3.4, auto, 4x4 236,000
    Only thing I had to have replaced was the frame
    TacoYankee likes this.
  17. Feb 18, 2018 at 1:51 PM
    #557
    Clement
    Clement New Member
    Phoenix AZ
    2001 Tacoma std cab 2wd 2.4L manual
    3” front spindle lift Pro Comp Explorer Shocks Magnaflow Exhaust BRAHMA camper shell
    I just bought a 2001 2RZ 2wd with 261k. She idles high and has an exhaust leak. I will be taking out the TB and IAC to clean soon. Also I'll be replacing the spark plugs and doing an oil change to get rid of the FRAM filter. I put some Seafoam in the tank, oil, and vacuum line. I barely got any smoke out the tailpipe.
  18. Feb 18, 2018 at 2:31 PM
    #558
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    2004, 268K still going strong. Just picked up a set of OEM 2017 rims and tires.
  19. Feb 18, 2018 at 2:41 PM
    #559
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    I'm getting suspicious of my front end suspension components. Not really looking forward to tackling that job.
  20. Feb 18, 2018 at 2:43 PM
    #560
    Camdg2010
    Camdg2010 Well-Known Member
    my 02 has 268xxx but the computer says 288xxx. i didnt swap computers when i swapped cabs.. either way. both run strong!
