200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Feb 18, 2018 at 2:52 PM
    #561
    Toy Yo
    Toy Yo Well-Known Member
    Middletown N.Y. upstate
    2017 tacoma TRD Sport
    2 inch front and rear lift kit, Rough country nerf step bars, Ultra Mongoose 17x9 wheels BF Goodrich M/T 285/70-17
    My sons 05 just turned 100,000. I owed it used from 18,000 till I got my new 17 in October.
  2. Feb 18, 2018 at 5:49 PM
    #562
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I just went through my entire front end and replaced almost everything. If you have any questions lemme know. I ended up buying quite a few tools in the process and it took a lot of evenings after work to do it. If I had second car or devoted an entire weekend it would have gone quicker but I spent a lot of time waiting and ordering parts and replacing thing after thing
    MedicMutt[QUOTED] likes this.
  3. Feb 18, 2018 at 7:04 PM
    #563
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    I love you.
    Seriously, I'll hit you up with questions at some point. My little buggy is rolling on original suspension parts at 243k. It's definitely given me good service, but I'm beginning to notice some fatigue. Thanks, man!
  4. Mar 10, 2018 at 8:07 PM
    #564
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    2025 SR5 4x4
    What engine maintenance did you guys do when you hit 200k?
  5. Mar 11, 2018 at 7:48 AM
    #565
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Changed oil and the spark plugs twice
  6. Mar 11, 2018 at 4:16 PM
    #566
    Railroad_Earth
    Railroad_Earth Well-Known Member
    Black 2010 DCSB
    Here is my 02 with 255k. Love this truck. Just paid it off a couple weeks ago. Excited to do some more mods! See ya later pay checks!!DBC87A27-7555-4524-AEB3-18321E0C37A1.jpg5D878E10-87DE-487E-AE1C-B3BF02671638.jpg
  7. Mar 14, 2018 at 10:06 PM
    #567
    rayrayr6
    rayrayr6 Member
    Ray
    Sylmar, CA
    03 Tacoma Dbl Cab TRD 4x4
    Bought with 275k from original owner . Extensive service records and clean CARFAX . Happy camper indeed
    JKU3000 likes this.
  8. Mar 15, 2018 at 11:13 AM
    #568
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Im getting closer...at 199103 ;)
  9. Mar 15, 2018 at 12:26 PM
    #569
    guacamoleparty
    guacamoleparty Member
    2001 SR5 Access Cab PreRunner
    One of my sway bar end links is bad/loose. Gives me a nice thunk every so often - should I just replace it with the factory one? On Toyota parts it shows its about an 80$ part (with dealer markup i imagine). My friend is a mechanic - and can most likely swap this for me. Should i have them look at anything else while Im down there? I have about 179k miles on my 2001. Should I do both at once or nah? Any suggestions would be great, thanks all!
  10. Mar 15, 2018 at 2:53 PM
    #570
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    everyone says theyre nice and helps handling. I dont have a sway bar so i dont really know...but if it sees a lot of pavement id probably get it
  11. Mar 15, 2018 at 3:44 PM
    #571
    tmack0
    tmack0 Member
    T
    SF
    2002 4x4 v6 LunarMist TRD 5spd 300k+
    2" lift billstien/OME + Hellwig half-leaf Red Leer camper shell deckplate mod, LED lights
    ~245000 here, 3 trips across the US coast to coast, plenty of time in the snow and dirt. Only normal maintenance items, clutch master/slave cylinders but still on the original clutch, an axle oil seal, entire suspension (for a ~2" lift at ~175k mi), brake rotors (OEMs kept getting runnout, EBC slotted/dimpled at ~60k and never had to bother them since), and about to do the front-diff needle bearing->bushing swap.
  12. Mar 17, 2018 at 7:24 AM
    #572
    SweetMiss
    SweetMiss Member
    Stacey
    New Westminster, BC Canada
    2003 Tacoma Crewcab TRD offroad
    Sexy as f***
    IMG_20180311_164805.jpg 317,000 kms over here(196,000 miles), swapped out the front diff for a used one. Learned I have 4.10gear ratio in the process. Also replaced the driver's side axel shaft...all that in the last week. Other than that we are running like a dream :)
    Jarvisdawg, 300kClub2001 and wilcam47 like this.
  13. Mar 17, 2018 at 10:40 AM
    #573
    wilcam47
    Will
    Bourbon state
    nice truck and view
  14. Mar 17, 2018 at 7:05 PM
    #574
    Fuzzy Dustmite
    Fuzzy Dustmite Active Member
    Greg
    Mesa, AZ
    02 DLX Lunar Mist / Grey
    My 2002 just rolled 200k
  15. Mar 18, 2018 at 10:11 PM
    #575
    emanuelr15
    emanuelr15 Active Member
    emanuel
    1998 tacoma 2004 Tacoma
    Whats up guys .so i had these velcro patches made a while ago i am currently sold out of the 100k but i will have some by next week.
    opteron, wilcam47, mxjagracer and 2 others like this.
  16. Mar 22, 2018 at 10:41 AM
    #576
    hdhntr
    hdhntr New Member
    01 dc 4x4
    280K .... 01 DC 4WD .... routine maint. only .... can't kill 'em
  17. Mar 23, 2018 at 10:58 AM
    #577
    Truth
    Truth Active Member
    '98 Tacoma TRD Limited; 3.4L V6
    2” rear body lift, 2.25” rear suspension lift; 3” front body lift (it’s in a transition period); OME rear springs+an extra leaf; Bilstein 5100s in the front; BFG 31x10.5s
    this is an old thread, but it appears some are still posting... I've got a '98 with 240k, it runs great just needs a slave cylinder, and front wheel bearing. other than that i runs fantastic. Around thanksgiving i drove it to Michigan from Southern Virginia which is about 800 miles. Since i bought it i've had several people tell me they'd love to buy it (NOPE!). I intend to keep it and keep fixing it until there's nothing left to fix anymore.
  18. Mar 29, 2018 at 2:06 PM
    #578
    mball
    mball Active Member
    Texas
    01 PreRunner
    Blisten 5100s up front and spacers in rear. Painted grill. Leer color matched topper.
    01 Prerunner 215K. Besides normal maintenance, I recently put on upper and lower ball joints and new tie rod ends. Absolutely NO problems from the engine or trans! Like a fine wine these trucks get better with time
  19. Mar 31, 2018 at 11:38 PM
    #579
    rae671
    rae671 Member
    Tina
    Tulsa
    03 prerunner 2wd
    03 prerunner 270k.. Normal maintenance. Its been a great truck. Drive it every day!
  20. Apr 5, 2018 at 8:16 PM
    #580
    mxjagracer
    mxjagracer Well-Known Member
    Asheville NC
    2000 Tacoma 4x4
    2000 sr5 4x4 2.7 246,000 and purrs like a kitten! Had to put in a bit of stuff when purchased from my buddy (the original owner) as it sat for 2 years. Still only about 2800 total investment, including the purchase price!!!
