200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Apr 11, 2018 at 12:46 PM
    #601
    03ForMe
    03ForMe East Texas
    Dave
    2003 Tacoma 4WD Xtra Cab 5 speed
    None
  2. Apr 11, 2018 at 4:01 PM
    #602
    BoiseBound
    BoiseBound Member
    2002 2wd 4cyl manual (original clutch) - 237,845 miles - zero problems from day one
    03ForMe likes this.
  3. Apr 12, 2018 at 10:40 AM
    #603
    interst8er
    interst8er Active Member
    Eugene
    Its red
    Header installed and the balance shafts removed. Bilstien front coil overs. Installed an instrument cluster from a 4cyl 4runner that had a factory tachometer. Polished Western Slot Mags. New cylinder head and new bearings and counter shaft in the trans.
    Im at 260000. Did the head, radiator, starter, clutch, steering pump, balance shaft removal kit, an AC tube under the dash, and it has an exhast header. Also it has Factory looking tachScreenshot_20180412-103912.jpg
    2002Tacoma4x4 and BassAckwards like this.
  4. Apr 14, 2018 at 9:33 PM
    #604
    BigBadRy
    BigBadRy New Member
    Colorado
    95 4X4 3.4L V6
    I have a '95 4x4 with 329,000. I did replace the motor at 294,000 because I must have melted a bearing in the block. Trying to pass a Semi up a 7% grade, loaded with extension ladders on top accelerating hard in 3rd gear. lost power and had to rev the gas to keep it running, but limped it 10 miles to the house in the CO mountains. I bought a used 3.4 to replace it with had 110K on that. I figured it was barely broke in.
    interst8er and 1997tacomav6 like this.
  5. Apr 16, 2018 at 9:46 AM
    #605
    Chucky1953
    Chucky1953 Active Member
    2018 TRD Off-Road
    Pro-Grille
    I"m new here. I got almost 270K on my 03 V6 Access cab. Frame replaced some years back by my dealer. I'm not a wrencher but have a good and honest mechanic. Gas tank straps let go last fall. Recently my fuel pump quit a few weeks ago and had to get towed back to my home town about 30miles away. So I decided to trade in and while I'm waiting for the model I wanted a rear wheel axle bearing locks up on my and my wrench doesn't have the right press to repair, so he has to remove the axle and send to shop which charges $300 press bearing set back on..............it has been a great truck for me here in New England and I'm the original owner. So I have to do a major repair once more to bring it in for trade....................Getting a new TRD Sport.
  6. Apr 16, 2018 at 10:38 AM
    #606
    1997tacomav6
    Denver
    Good luck with that and make sure you get a bumper to bumper warranty for as long as you can, I know the transmissions still have problems. Its all over the site here.
    My brothers Tacoma left him stranded a few times because the anti theft computer part went hay wire and would not let the truck to start.
    Ended up having to replace the ECU for 2500.00 and of course the ECU has to be programmed by the dealer.
    Lots of electrical nightmare issues with the new trucks.
    So what are car payments and insurance on that just out of curiosity
  7. Apr 16, 2018 at 3:11 PM
    #607
    Chucky1953
    2018 TRD Off-Road
    Pro-Grille
    It will depend on what I put down. And they're giving me 3500 for my truck. They are also a GREAT dealer. The best in my area by far. I bought my last 2 trucks there. Maybe about 400 per month if I string it out. I"m financing through my local CU and could get 3.50 for six years. . I'm looking at a 6 speed after reading THIS and other forums. I was considering a Colorado. I did drive an LT which I thought was nice. But I wanted a stick. To me the Taco feels more solid. Maybe it's just me. Been driving Toyota since 83. I was looking at the Colorado fan forums and they're talking about the hood vibrating on the highway and some electrical problems.
    If I keep reading all the forums, I won't get anything. I appreciate all info. Funny consumer reports and others have bad things to say about the Taco, but then flip it over and say bad things about Colorado. Those were the only 2 I"ve been considering. Yes, I'm having some issues now, but never had a vehicle for this long. If I thought I could trust the Colorado for 200K...…...and forget I want a CD player, and the choice for a standard shift...……. I have a deposit down, but I'm not locked in. The new Taco sure rides a lot better than my 2003!!!
  8. Apr 16, 2018 at 7:28 PM
    #608
    wRikWrek
    wRikWrek Active Member
    Rick
    Santa Cruz
    2004 DC 4x4
    3 inch Bilstein coilovers, OME leafs, on 33x12.50x15
    215k on mine. Just did the timing belt service for the second time at 188k and running strong!
  9. Apr 17, 2018 at 4:41 PM
    #609
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    As of a few days ago, I'm at 196,825 miles so I'm close to joining this club!
    I am due for front wheel bearings (because I feel like it's the right thing to do since they are original) and ball joints. The LBJs were replaced at 17k under the recall and now they have a slight weep of grease but I don't feel any play from yanking at the wheel in any direction.
    Pilot0527 likes this.
  10. Apr 19, 2018 at 5:10 PM
    #610
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    Hank's odometer as of today...
    2002Tacoma4x4 likes this.
  11. Apr 19, 2018 at 5:11 PM
    #611
    Pilot0527
    Pilot0527 Well-Known Member
    West TN
    2003 Tacoma Prerunner flareside
    3" lift, aftermarket cruise control, helo wheels chrome, ARB rear airlocker, linex bedliner, Dee's aluminum toolbox
    2003 just regular maintenance. Ujoints and carrier bearing about 2000 miles ago. Runs like a brand-new one. Happy to be part of this club. Hopefully this truck makes it to my 7 year old daughter..
  12. Apr 29, 2018 at 6:53 AM
    #612
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    2003 DC 4x4...218,xxx miles as of today...no pics, because who lies about their age?
    :anonymous:
  13. Apr 29, 2018 at 4:39 PM
    #613
    Railroad_Earth
    Railroad_Earth Well-Known Member
    Black 2010 DCSB
    04yota likes this.
  14. Apr 29, 2018 at 5:16 PM
    #614
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’m at 442,000 miles on my 1998 5-Lug v6.
    Paid a whole $600 for it.
    My 1998 PreRunner 4x4 has a long way to go, it only has 94,000 miles.
    wilcam47 and TacoHank1998 like this.
  15. Apr 29, 2018 at 6:36 PM
    #615
    tacama321
    tacama321 Active Member
    Mondo
    Amarillo, TX
    1997 Toyota Ext.Tacoma 4x4 3.4L
    268000 plus., 200000 from first owner in 3 years, 30,000 from second in 10 , 37,000 from third in 7 years. I am sure there are many more miles to come.
  16. Apr 30, 2018 at 9:16 PM
    #616
    albert7991
    albert7991 Active Member
    Albert
    Vancouver WA
    99 Red Tacoma SR5 TRD Off Road 200K+
    Fabtech suspension 4.5" lift Rolling on 33s Gutted
    I am just at about at 197k miles and i just did valve cover gaskets spark plug wires and spark plugs. Also will be doing fuel filter and engine mounts soon already have the parts.
  17. May 2, 2018 at 7:16 PM
    #617
    socarboy99
    socarboy99 Pluggin' along by going from A to B to C to D...
    Charleston, SC
    1999 Tacoma Regular Cab 2WD
    TLC (Toyota Loving Care), Kenwood Head Unit with bluetooth
    That's EXACTLY why I love the 1st gen Taco
    tacomakid96[QUOTED] likes this.
  18. May 3, 2018 at 5:25 AM
    #618
    LDHunter
    LDHunter New Member
    2002 4WD Extended Cab Silver
    My 2002 4WD Extended Cab is a little over 210,000. It's almost broken in. I bought it new and have never had any serious problems with it. Amazing little truck.... It was also my first Toyota and I've since had several others but the Taco has a permanent place here.
  19. May 3, 2018 at 4:35 PM
    #619
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Same here. She rides so good now, like night and day. UBJ were a bit of a pain though.
  20. May 3, 2018 at 4:36 PM
    #620
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    Nice! You should make them in decals or badges to put on the truck.
