200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Dec 30, 2018 at 1:11 PM
    #781
    Avreal92
    Avreal92 Well-Known Member
    1998 White(for now) Tacoma Limited TRD
    Mine's a '98 I bought with 280k. Up to about 324k(ish) and still going strong. Haven't changed the motor or trans yet (though I want to eventually swap to a manual and put in a supercharger, too broke to do that yet)
  2. Dec 30, 2018 at 11:26 PM
    #782
    BadAppleTaco
    BadAppleTaco New Member
    02 Tacoma
    02 bought new. 275k on 2.7 motor trans and factory installed supercharger. Runs like a top!
  3. Jan 1, 2019 at 8:40 PM
    #783
    04Pre_Runner
    Andrew
    San Angelo, Texas
    2004 DC Tacoma SR5 4WD V6
    OME Suspension, 4WD Conversion, ARB Bumper
    Not a Tacoma I know. My aunt has been driving a 2001 4Runner with the original 5VZ/A340E since it was at 30K. It's now at 417,205. All the work on it follows the recommended service schedule.
    lf1Jd0cy0CGVsVxd6km4iXYweSZeFTqZX8Yftxff_2f367a9fca2d8191fc80c8c472e9f96ae2f67c76.jpg
    QMEDJoe, tacomakid96 and tmee like this.
  4. Jan 2, 2019 at 11:19 AM
    #784
    tmee
    tmee New Member
    Tim
    Colorado
    2001 xtra cab v6 5 speed
    oil, tires, and recovery gear
    first owner took it to 160k, hoping I can bring it at least that much further.
  5. Jan 6, 2019 at 8:18 AM
    #785
    Robert61899
    Robert61899 Well-Known Member
    Robert
    Blacked out 2004 Toyota Tacoma Double Cab
    241.5k and still going strong
  6. Jan 6, 2019 at 8:19 AM
    #786
    Robert61899
    Robert
    Only thing I’ve changed is power steering pump
  7. Jan 9, 2019 at 8:06 PM
    #787
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    1995 2.4 man 320,000
  8. Jan 18, 2019 at 6:15 AM
    #788
    aroma
    Snottsdale AZ
  9. Jan 21, 2019 at 12:25 PM
    #789
    Eisenhower
    Eisenhower Member
    Southern Oregon
    Reached a milestone today
  10. Jan 23, 2019 at 5:38 AM
    #790
    Byrdseason
    Byrdseason New Member
    Derek
    96 extended cab 2.7
    2.5 inch bilstein lift , icon add-a-leaf 31" ko2s
    286,000 on my pig
  11. Jan 30, 2019 at 11:13 AM
    #791
    steve2267
    steve2267 Well-Known Member
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    Bought my 2004 Taco DC with 172,000 in 2014. Promptly replaced timing belt and water pump at the same time. Oil & filter changes every 5,000 miles with full synthetic. Only thing that comes to mind is I replaced the fuel pump (in the gas tank), had the plugs and wires done once (I think they may be due again), and have had to do the brakes a few times (normal wear). Am at 269,000+ miles, still running well. Mine is a work truck.
  12. Jan 30, 2019 at 11:47 PM
    #792
    kokose7en
    kokose7en Well-Known Member
    Just slightly above 200k!
  13. Jan 31, 2019 at 6:28 AM
    #793
    vorabora99
    vorabora99 Well-Known Member
    Dan
    Virginia
    Stock all the way!
    wow that is clean. how long have you had it
  14. Jan 31, 2019 at 11:28 AM
    #794
    kokose7en
    2 days now! I love it!
  15. Jan 31, 2019 at 11:29 AM
    #795
    vorabora99
    Dan
    Virginia
    Stock all the way!
    wow! ! how much ?? and is it 2wd or 4wd
  16. Jan 31, 2019 at 11:33 AM
    #796
    kokose7en
    4WD! $8k
    vorabora99 likes this.
  17. Feb 1, 2019 at 2:56 PM
    #797
    synergy10
    synergy10 Well-Known Member
    San Diego
    Just under 230k on mine:
    Flare side Taco Lover likes this.
  18. Feb 1, 2019 at 3:19 PM
    #798
    steve2267
    Colorado
    Is that a Taco or a 4Runner? If a Taco, did you do any mods? Thought the 4WD pushbutton on the transfer case shift lever only came on 4Runners?
  19. Feb 1, 2019 at 3:33 PM
    #799
    synergy10
    San Diego
    Mine is the same as in the picture (push button for 4 hi). My brother in laws 99 4runner doesn't have the push button so he has to shift into 4 hi).
    My interior (you can barely see the 4wd button):
    Don't think I have a pic of the interior of my BIL's 4runner though.
    (found a pic):
  20. Feb 1, 2019 at 3:41 PM
    #800
    steve2267
    Colorado
    Now I am thoroughly confused. So if the 4WD button get's you "4HI", what happens....
    Let me try again, a light bulb may have just gone off...
    So you normally run around with the transfer case shift lever to the rear in the H position? (I was interpreting H as 4HI.) When you want 4HI (i.e. T-case high range, but power to front and rear), you push the magical 4WD button?
    Moving the transfer case shift lever forward to 4LO then gets you Low range on the Transfer case?
    Question: Can you shift the transfer case shift lever forward without depressing the 4WD button? Will that get you Low range, but 2WD (rear) only? Or does moving the transfer case shift lever forward automatically engage 4WD (i.e. power to the front axle)?
