200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Feb 12, 2021 at 3:32 AM
    #1181
    NehemiahJantomaso
    NehemiahJantomaso Active Member
    Nehemiah
    1999 Tacoma SR5
    2.5' lift on 265's
    Just hit 252,000, still runs like a CHAMP
    tacomakid96 and Ellis42sbgtf like this.
  2. Feb 15, 2021 at 2:17 PM
    #1182
    Matatochip
    Matatochip New Member
    03 Silver Taco dbl cab
    232600 for mine, running strong!
    tacomakid96 likes this.
  3. Feb 15, 2021 at 2:29 PM
    #1183
    Taco1UU
    Taco1UU Member
    Two Tacos: 1996 and 2002
    No mods yet on the '96...just trying to get her reliable again. Work completed: * Cleaned behind dash and replaced all dash bulbs. (There was only one working.) * Reconditioned front bumper. Replaced rear bumper. * Thoroughly corrosion-controlled underside, including spare tire hardware. * Replaced valve cover and engine oil pan gaskets. * Replaced clutch. * Replaced all driveline fluids. * Engine tuneup. * Reconditioned gas tank skid plate. * Reconditioned engine skid plates. * Replaced parking brake hardware. * Replaced all front suspension components except lower control arms. * Replaced front brakes. * Replaced CV joints. * New main driveshaft No mods on the 2002...she's all stock.
    1996 standard cab: bought at 252K, now 269K and going strong. Replaced all front suspension parts, front CVs & axle seals, front & rear brakes, oil pan and valve cover gaskets, belts, hoses, clutch, flywheel, driveshaft universals, parking brake cable, spark plug wires, distributor cap, and dashboard light bulbs. Rehab'd front hubs. Burns no oil. Did some frame rust control and think there's another five years before I need to consider some radical frame surgery.
  4. Mar 1, 2021 at 6:21 AM
    #1184
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    Where do you buy the patches?
    Which Way Out likes this.
  5. Mar 1, 2021 at 10:49 AM
    #1185
    PRBond
    PRBond Well-Known Member
    Patrick
    Columbus, OH
    04 TRD PreRunner
    3" ToyTec suspension kit, AEM Air Intake, Uniden 510 CB, 265 X 75 X 16 BFG AT's
    201,860 and she runs just as good as the day I drove her from the Toyota dealer back in December of '03.
  6. Mar 4, 2021 at 10:48 AM
    #1186
    Turtlen8
    Turtlen8 New Member
    Nathan
    '99 Tacoma 2.7L
    3" OME LIft, Falken Wildpeak, Method Wheels, High Boost Supercharger, Magna Flow exhaust, Cold Air intake
    1999 One owner (me) Around 312k miles
  7. Mar 11, 2021 at 5:55 PM
    #1187
    JaxPearlTaco
    JaxPearlTaco Amateur Decision Specialist
    Brian
    Jacksonville, FL
    1997 Ext Cab 4x4 5 speed 3.4
    N/A
    265k and still going strong!
  8. Mar 12, 2021 at 1:28 PM
    #1188
    Duderz7
    Duderz7 Member
    Dann
    95.5 Tacoma SC 3.4 4x4
    Stock
    214+ runs super smooth.
  9. Mar 13, 2021 at 7:19 AM
    #1189
    circuit-maker
    circuit-maker Member
    J
    PNW
    `96 Toyota Tacoma 3.4L DLX 4x4 AT Sunfire Red
    273k, kept stock. 1 owner before me, came with dealer paperwork. Still purrs...
  10. Mar 14, 2021 at 5:31 PM
    #1190
    Chrucks
    Chrucks Member
    2003 Tacoma Doublecheeseburger
    290,008. Keep on Truckin'! (2003 Double-cab 4x4)
  11. Mar 20, 2021 at 6:05 PM
    #1191
    1stgenlurker
    1stgenlurker Member
    2004 Xtra Cab Tacoma TRD 4x4 Imperial Jade MIca
    Bought an 04 with 247k for 6k today. Previous owner was pretty meticulous about maintenance and I'm excited to see how far this 1st gen gem will take me.
    unstpible, 2pei, tacomakid96 and 2 others like this.
  12. Apr 2, 2021 at 2:17 PM
    #1192
    Ellis42sbgtf
    Ellis42sbgtf Well-Known Member
    Kyle
    Birdsboro, PA
    2004 Tacoma DBL 4x4 3.4L
    I bought mine at 267k and now she has 325k...you got a good deal!
  13. Apr 4, 2021 at 8:27 AM
    #1193
    1stgenlurker
    1stgenlurker Member
    That's what I like to hear!
  14. Apr 9, 2021 at 4:02 PM
    #1194
    Jdub509
    Jdub509 Member
    Cashmere
    black 99 sr5 mt and black 17 TRD sport mt
  15. Apr 20, 2021 at 5:31 AM
    #1195
    Ellis42sbgtf
    Kyle
    Birdsboro, PA
  16. Apr 27, 2021 at 6:19 PM
    #1196
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    IMG_1402.jpg IMG_1586.jpg 330,000 or so happy & troublefree miles, about 1/4 of them off road
  17. Apr 30, 2021 at 12:47 AM
    #1197
    frankiep310
    frankiep310 New Member
    frankie
    2000 Tacoma 4x4 5speed BASE
    654F8D19-5C9B-4ADC-BAD0-D8024B437120.jpg I got a 2000 with 298k I love my little taco. 654F8D19-5C9B-4ADC-BAD0-D8024B437120.jpg
  18. May 2, 2021 at 6:08 PM
    #1198
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    This is an inspiring thread. There is a good chance my 2004 will be on the road in 2080! I mean, it is an '04 with 63k miles.
    How many have hit 300k with the original engine and transmission? I know of a much older Toyota where I work. It's an early '80's pickup with 348k miles last time I talked to the owner. He has not replaced the engine or transmission, but did replace the clutch once. It is rusted all to #&!$ and does smoke a bit on a cold start, but it by the time he is leaving the parking lot there is no visible smoke and the old thing sounds good (unless a rear fender happens to be rattling against the inner fender well.) He commutes around 50 miles a day in it!
  19. May 2, 2021 at 8:19 PM
    #1199
    2pei
    Scott
    Oregon High Desert
    03 Tacoma
    2.7l with manual. My factory starter crapped out at 289K, first thing ever to fail. I had the local Toyota truck guy swap it out along with the factory alternator, water pump, clutch and driveline. The compression was fine and valves were withn spec, first time the valve cover was off. I change all the fluids every 2 years. 330K now and doing great
  20. May 11, 2021 at 8:34 PM
    #1200
    Cstem00
    Cstem00 New Member
    Cory
    Glendale, Arizona
    2004 Tacoma 4x4
    None yet
    I am super impressed and thank you for validating my latest buy. 2004 Extended cab 4wd, V6. 163k miles. $9000. I know the only two owners very well, and the truck has been mechanically maintained religiously. Has some interior panel light issues. Easy fix. I'm glad to be a Toyota owner again.
